Activity › Forums › Apple Final Cut Pro Legacy › FCP and editing HD100 true 24p???
  • FCP and editing HD100 true 24p???
    Posted by Tim Baker on August 16, 2005 at 12:55 am
    I am getting my HD100…hopefully by the end of the month.
    Am I going to need a third party plug-in or something to take advantage of the true 24p frame rate? If so, which plug-in seems to be the best?
    I just see a lot of posts about people having trouble editing true 24p in FCP 5, which I have.
    I also have the Kona2 with Kbox and I/O LA and all current firmware updates…does the input process used make a difference? I am planning on using the composite or component out of the HD100 into my Kbox…is that the right direction to go? Maybe firewire, but I figure that would be used only if I shoot in standard DV mode. I also see that the camera will internally convert to 1080i so I figure the Kbox is the way to go, especially for that.
    I can’t wait to get the camera, but I will be new to posting HD.
    Thanks all.
    Tim Baker
    Chameleon Mobile Video Productions
    (239)849-3295
    “It is not the light at the end of the tunnel that we should seek…it is the courage to take the next step in the dark that we must find.”
    Gary Adcock replied 21 years, 1 month ago 2 Members · 2 Replies
  • Gary Adcock
    August 16, 2005 at 1:49 am
    [Tim] “Am I going to need a third party plug-in or something to take advantage of the true 24p frame rate?”
    Yes, since 24p is not supported in the HDV codec.
    [Tim] “does the input process used make a difference? I am planning on using the composite or component out of the HD100 into my Kbox.”
    Yes it does
    and this is a fine solution – but you will need a HD10a converter to get the component signal from the camera to the Kbox
    gary adcock
    Studio37
    HD and Film Consultation
  • Gary Adcock
    Yes it does
    gary adcock
    Studio37
