Activity Forums Apple Final Cut Pro Legacy FCP and Compressor – creating two files?
  • FCP and Compressor – creating two files?
    Posted by Lawrence Eaton on October 16, 2009 at 2:37 pm
    When I export to compressor and choose a profile I find that I get the little yellow triangle with the exclamation mark in it. When I pass my cursor over it I get the tool tip: “This target will overwrite an existing file with the same name. To preserve the existing file change the destination or change the name of the output file.”
    1)The destination is a separate drive.
    2)The output name is unique to every file – without fail.
    Does compressor go into ‘shock’ when a codec is multipass?
    Puzzled and flustered,
    Lawrence
    Lawrence Eaton
    Joel Wenz replied 16 years, 11 months ago 2 Members · 1 Reply
  • Joel Wenz
    October 20, 2009 at 4:33 am
    have you tried changing the name within compressor? Just add the number 1 to the end of the name and the mark should go away…
