Activity Forums Apple Final Cut Pro Legacy FCP and AVID play together NICE
  • David Roth weiss
    August 23, 2005 at 4:56 pm
    Mike,
    In either case, you can easily clone your boot drive to an external firewire drive and install the each peice of software on its own bootable system drive.
    DRW
  • Southpaw
    August 23, 2005 at 7:25 pm
    Howdy. I’ve got FCP 4.5 and AXP 4.6 with Mojo and they run on the same machine with no problems. Just not at the same time, of course.
    hope it helps.
    dan
  • Wes Plate
    August 23, 2005 at 11:42 pm
    I frequently run Xpress Pro and FCP together on the same machine. The only issue is if I have a deck attached, FCP can’t use it because the Avid takes it or the other way around. Anyway, as long as I don’t have a deck attached I have no issues running them at the same time, and I even less than no problem running them separately but installed on the same machine.
    — Wes Plate
    Automatic Duck
