Activity Forums Apple Final Cut Pro Legacy FCP and Audio output to tape
  • FCP and Audio output to tape
    Posted by Yiannis Valkan on June 11, 2009 at 3:03 pm
    Hi all.
    I am using FCP with AJA Kona3 for outputing to M2000P Digi Beta Recorder via SDI output.
    I have a sequence with one video stream and 2 stereo audio streams in channels 1-2 & 3-4.
    What i cannot manage is to output each channel from FCP to the same channel in M2000P.
    for e.g. CH1&2 from FCP to 1&2 in Tape and 3&4 from FCP to 3&4 in Tape.
    It was working but i must have done something to the settings and now i cannot fix it.
    In Audio Output in Sequence settings, the audio preset is set to 4 and the grouping is Dual Mono.
    Does anyone have any idea how to fix that?
    Thank you.
    Stuart Bruce replied 17 years, 2 months ago 3 Members · 4 Replies
  • Yiannis Valkan
    June 11, 2009 at 3:07 pm
    What i forgot to say is that i DO have audio export but all the files are mixed to CH1&CH2 of the tape.
    2 minds are better than one.
  • Michael Gissing
    June 11, 2009 at 11:23 pm
    Firstly your sequence settings in the audio tab must be set for 4 channel output.
    Then on the timeline, control click on the audio channels (down near the padlock symbol) and you will see a menu pop up to set each channels output.
  • Yiannis Valkan
    June 12, 2009 at 5:21 pm
    Thanks Michael, That worked great!
  • Stuart Bruce
    July 11, 2009 at 10:45 am
    I didn’t ask this question, but I found this answer when searching the Cow and it has been a life-saver for having to deliver under pressure. So thank you!
