Activity Forums Apple Final Cut Pro Legacy FCP and After Effects Windows: best codec?
  • FCP and After Effects Windows: best codec?
    Posted by Zopiro Da tracia on July 30, 2014 at 8:00 am
    I still do a lot of FCP7 editing using Apple ProRes codec on my Mac. Since I recently acquired a very fast PC, I plan on using it for work on After Effects CS6 (soon CC).
    I’ll be moving rendered files from FCP7 to AE and vice-versa. I noticed AE on Windows lacks the ProRes codec. I’ve tried rendering in AE using Lossless in both QT and AVI but when importing to FCP there’s a very noticeable color difference…
    What’s my best course of action here?
    Walter Soyka replied 12 years, 1 month ago 2 Members · 1 Reply
  • Walter Soyka
    July 30, 2014 at 5:29 pm
    Final Cut Pro misinterprets the gamma on RGB formats.
    Import the clip into FCP. Select the clip, then hit Cmd-9 to open Item Properties. Right-click the gamma value (normally set to Source) and set it to 2.2.
    Other options:
    Miraizon has a ProRes-compatible codec for Windows. You could try encoding with that.
    You could also consider running Premiere Pro on your PC alongside Ae.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
