Activity Forums Apple Final Cut Pro Legacy fcp and ae firewire out problem
  • fcp and ae firewire out problem
    Posted by Anne Pascal on March 20, 2006 at 7:38 pm
    Hi All,
    I have just posted below the problem of no DV out on the FCP 4.5 after an upgrade of FCP and a Qtime upgrade to 7. This problem is also found in After Effects 6.5, where I cannot have a DV PAl out for preview anymore.
    I really curse the upgrade I made!!!!
    Trashing of receipts of Quicktime dis not work
    Anyway can I go back like to an older state of my computer: have the old versions prior to the upgrade: an old system THAT WORKS!!!!!
    Please help
    Anne
    anne pascal
    Jeremy Garchow replied 20 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    March 20, 2006 at 7:49 pm
    How did you install, did you simply do an upgrade or did you do a full ground up reinstall? If you didn’t do a wipe and install you should as you will have significantly fewer hiccups.
    Jeremy
