Activity Forums Apple Final Cut Pro Legacy FCP – Altered Setting
  • FCP – Altered Setting
    Posted by Pal Media on April 6, 2006 at 8:04 pm
    Have you ever changed something within your Final Cut setup that you can not for the life of you determine how to reverse?
    Here I sit……
    My dilema is as follows:
    When you are working thru a clip – usually .. you can use the JKL buttons and the arrows to browse ….. and under normal use.. when you arrow left and right… usually there is audio ….. now… when browsing a clip with the arrow keys – there is no audio present so pinpointing is increasingly difficult
    Did I turn something off? or have and of you ever encountered such an issue before
    Help
    Robert Garry replied 20 years, 5 months ago 2 Members · 1 Reply
  • Robert Garry
    April 6, 2006 at 8:45 pm
    Just a guess but see if Audio Scruubing is turned off – View>Audio Scrubbing
    Hope it helps
    Bob
