fcp aja kona report 9
I get this error when working with Final Cut constant. Can you help me?
Final Cut Pro quit unexpectedly while using the AJAVideoOutput plugin
Process: Final Cut Pro [1211]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [136]PlugIn Path: /Library/QuickTime/AJAVideoOutput.component/Contents/MacOS/AJAVideoOutput
PlugIn Identifier: com.aja.kona.videooutput
PlugIn Version: 10.3.2 (10.3.2)Date/Time: 2012-09-24 17:16:00.977 +0300
OS Version: Mac OS X 10.7.5 (11G56)
Report Version: 9Interval Since Last Report: 162688 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 148111 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: 1955AF6F-63F3-40E2-844C-E35F85F4A527Crashed Thread: 57
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000VM Regions Near 0:
–> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] —/— SM=NUL /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
__TEXT 0000000000001000-0000000000871000 [ 8640K] r-x/rwx SM=COW /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut ProApplication Specific Information:
objc[1211]: garbage collection is OFFThread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x98b25bb2 __semwait_signal + 10
1 libsystem_c.dylib 0x99db07b9 nanosleep$UNIX2003 + 187
2 libsystem_c.dylib 0x99db0558 usleep$UNIX2003 + 60
3 com.aja.kona.videooutput 0x2d1efef0 APW::VO::Alpine::VideoOutput::BandDecompress(APW::Alpine::DecompressRecord*) + 4450
4 com.aja.kona.videooutputcodec 0x27248830 myCodecBandDecompress(CodecGlobals*, CodecDecompressParams*) + 4407
5 com.apple.CoreServices.CarbonCore 0x955b4334 callComponentStorage_44 + 25
6 com.apple.CoreServices.CarbonCore 0x9566343d _ZL38CallComponentFunctionCommonWithStoragePPcP19ComponentParametersPFlvEm + 45
7 com.apple.CoreServices.CarbonCore 0x9566347d CallComponentFunctionWithStorageProcInfo + 30
8 com.aja.kona.videooutputcodec 0x27249e62 myCodecComponentDispatch + 64
9 com.apple.CoreServices.CarbonCore 0x955d9415 CallComponent + 223
10 com.apple.CoreServices.CarbonCore 0x955d945e CallComponentDispatch + 29
11 com.apple.QuickTime 0x9128be72 ImageCodecBandDecompress + 43
12 com.apple.QuickTime 0x9127eb68 DoBandedDecompress + 18713
13 com.apple.QuickTime 0x9127a1e6 ICMAction + 2916
14 com.apple.QuickTime 0x9127949a ICMDeviceLoop + 4098
15 com.apple.QuickTime 0x912804f6 DecompressSequenceFrameWhen + 748
16 com.apple.FinalCutPro 0x0043aae9 VideoOutput::PostOutput(Output*, long long, BufferIndexEnum, bool, float) + 2631
17 com.apple.FinalCutPro 0x0042c872 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 1848
18 com.apple.FinalCutPro 0x0042d495 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 45
19 com.apple.CoreServices.CarbonCore 0x955b4821 callComponentStorage_44444 + 47
20 com.apple.CoreServices.CarbonCore 0x9566343d _ZL38CallComponentFunctionCommonWithStoragePPcP19ComponentParametersPFlvEm + 45
21 com.apple.CoreServices.CarbonCore 0x9566347d CallComponentFunctionWithStorageProcInfo + 30
22 com.apple.FinalCutPro 0x00426221 FCPMHDispatch(ComponentParameters*, char**) + 59
23 com.apple.CoreServices.CarbonCore 0x955d9415 CallComponent + 223
24 com.apple.CoreServices.CarbonCore 0x955d945e CallComponentDispatch + 29
25 com.apple.QuickTimeComponents.component 0x9bb20c5b 0x9af5d000 + 12336219
26 com.apple.QuickTimeComponents.component 0x9b5a17ac 0x9af5d000 + 6571948
27 com.apple.QuickTimeComponents.component 0x9b59d6d2 0x9af5d000 + 6555346
28 com.apple.CoreServices.CarbonCore 0x955b4821 callComponentStorage_44444 + 47
29 com.apple.CoreServices.CarbonCore 0x9566343d _ZL38CallComponentFunctionCommonWithStoragePPcP19ComponentParametersPFlvEm + 45
30 com.apple.CoreServices.CarbonCore 0x9566347d CallComponentFunctionWithStorageProcInfo + 30
31 com.apple.QuickTimeComponents.component 0x9b59d0b4 GenericComponentDispatch + 64
32 com.apple.CoreServices.CarbonCore 0x955d9415 CallComponent + 223
33 com.apple.CoreServices.CarbonCore 0x955d943c DelegateComponentCall + 24
34 com.apple.FinalCutPro 0x0042623d FCPMHDispatch(ComponentParameters*, char**) + 87
35 com.apple.CoreServices.CarbonCore 0x955d9415 CallComponent + 223
36 com.apple.CoreServices.CarbonCore 0x955d945e CallComponentDispatch + 29
37 com.apple.QuickTime 0x912c13b0 MediaMoviesTask + 61
38 com.apple.QuickTime 0x912c04f0 TaskMovie_priv + 3712
39 com.apple.QuickTime 0x912ce2c9 MoviesTask_priv + 91
40 com.apple.FinalCutPro 0x001ba928 DoMoviesTask(KGPlayerRec*) + 2388
41 com.apple.FinalCutPro 0x001cd651 DisplayMovie(KGPlayerRec*) + 2201
42 com.apple.FinalCutPro 0x001d23ff pKGPlayerGoto(KGPlayerRec*, double, long, unsigned char) + 509
43 com.apple.FinalCutPro 0x001bb173 PlayerNotify(long, long, KGDictInt*, void*) + 149
44 com.apple.FinalCutPro 0x00113d97 DispatchNotificationsHelp(void**, KGDictInt*, long, long, unsigned char) + 157
45 com.apple.FinalCutPro 0x0011408b DispatchNotifications + 273
46 com.apple.FinalCutPro 0x0001e4cb HashInsertFull(HashDict*, char*, long, unsigned char, void*, KGTypeValueContainer*, void**, unsigned char, KGDictNotifyHolder**, KGDictUndoMethod, long, unsigned char, unsigned long) + 1083
47 com.apple.FinalCutPro 0x0001fb7d DispatchHashDict(KGDictSelector, KGDictInt*, KGDictParams*) + 221
48 com.apple.FinalCutPro 0x00114de6 pKGDictPut1(KGDictInt*, void*, long, char*) + 88
49 com.apple.FinalCutPro 0x000999eb ClipSetPositionHelp(KGDictInt*, double) + 229
50 com.apple.FinalCutPro 0x0009a0ae pKGClipGotoNextEdit(KGDictInt*, double, long, unsigned char) + 150
51 com.apple.FinalCutPro 0x000aabb8 pKGClipHandleDefaultMenu(KGDictInt*, long, unsigned char) + 9610
52 com.apple.FinalCutPro 0x001d7204 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 872
53 com.apple.FinalCutPro.Plugins.Timeline Editor 0x22461f70 TLTimeRemapGetChangeType(KGDictInt*, KGItemSpec*, double, KTPartKind, long) + 102226
54 com.apple.FinalCutPro 0x002b1ae1 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 2103
55 com.apple.FinalCutPro 0x0025e872 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120
56 com.apple.FinalCutPro 0x0025fd1c TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 110
57 com.apple.FinalCutPro 0x002a7781 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
58 com.apple.FinalCutPro 0x002bd5a3 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 91
59 com.apple.FinalCutPro 0x0015099b HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 417
60 com.apple.FinalCutPro 0x00150b11 HandleCommand(long, unsigned char, unsigned char, unsigned char) + 263
61 com.apple.FinalCutPro 0x0015695a HandleKeyDown(OpaqueEventRef*, KGDictInt*, KGWindowRec*) + 1404
62 com.apple.FinalCutPro 0x001587a1 DoEvent(OpaqueEventRef*, KGDictInt*) + 3117
63 com.apple.FinalCutPro 0x00414501 Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 67
64 com.apple.HIToolbox 0x95d9dc0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
65 com.apple.HIToolbox 0x95c19313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
66 com.apple.HIToolbox 0x95c18790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
67 com.apple.HIToolbox 0x95c185a8 SendEventToEventTargetWithOptions + 75
68 com.apple.HIToolbox 0x95c2de5e _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 2280
69 com.apple.HIToolbox 0x95c197ce _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 2813
70 com.apple.HIToolbox 0x95c18790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
71 com.apple.HIToolbox 0x95c2d571 SendEventToEventTarget + 76
72 com.apple.HIToolbox 0x95d9da58 ToolboxEventDispatcher + 82
73 com.apple.HIToolbox 0x95d9db87 RunApplicationEventLoop + 236
74 com.apple.FinalCutPro 0x001539d1 KGMainEvent(void*) + 51
75 com.apple.FinalCutPro 0x002c1278 main + 54
76 com.apple.FinalCutPro 0x00002d5b _start + 209
77 com.apple.FinalCutPro 0x00002c89 start + 41Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x98b2690a kevent + 10
1 libdispatch.dylib 0x9ce69e04 _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x9ce68853 _dispatch_mgr_thread + 53Thread 2:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x98b25b42 __select + 10
1 com.apple.CoreFoundation 0x97cb9e15 __CFSocketManager + 1557
2 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
3 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 3:
0 libsystem_kernel.dylib 0x98b2583e __psynch_cvwait + 10
1 libsystem_c.dylib 0x99dffe78 _pthread_cond_wait + 914
2 libsystem_c.dylib 0x99da782a pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043f42b Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x0042911f DisplayQueue::Run() + 681
5 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
6 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 4:
2 libsystem_c.dylib 0x99dfff7b pthread_cond_timedwait_relative_np + 47
3 com.apple.Foundation 0x90e583c3 -[NSCondition waitUntilDate:] + 427
4 com.apple.Foundation 0x90e1e7d2 -[NSConditionLock lockWhenCondition:beforeDate:] + 294
5 com.apple.Foundation 0x90e1e6a6 -[NSConditionLock lockWhenCondition:] + 69
6 com.gluetools.ARRIRAWComponent 0x2450f63f -[ARRI_ThreadSafeQueue dequeue] + 47
7 com.gluetools.ARRIRAWComponent 0x245465b5 -[GT_OperationQueue executeThread] + 133
8 com.apple.Foundation 0x90e25e25 -[NSThread main] + 45
9 com.apple.Foundation 0x90e25dd5 __NSThread__main__ + 1582
10 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 5:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 6:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 7:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 8:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 9:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 10:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 11:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 12:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 13:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 14:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 15:
11 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 16:
4 com.apple.FinalCutPro 0x004e67c3 WorkUnitPerformer::Run() + 55
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 17:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 18:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 19:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 20:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 21:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 22:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 23:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 24:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 25:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 26:
7 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 27:
0 libsystem_kernel.dylib 0x98b23c22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x98b231f6 mach_msg + 70
2 com.apple.CoreFoundation 0x97c629da __CFRunLoopServiceMachPort + 170
3 com.apple.CoreFoundation 0x97c6bb04 __CFRunLoopRun + 1428
4 com.apple.CoreFoundation 0x97c6b1dc CFRunLoopRunSpecific + 332
5 com.apple.CoreFoundation 0x97c7bf01 CFRunLoopRun + 129
6 com.apple.DVCPROHDMuxer 0x2c79798f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
7 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
8 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 28:
5 com.apple.CoreFoundation 0x97c6b088 CFRunLoopRunInMode + 120
6 com.apple.CoreMediaIOServicesPrivate 0x010f2223 MIO::DAL::RunLoop::OwnThread(void*) + 155
7 com.apple.CoreMediaIOServicesPrivate 0x010f4380 CAPThread::Entry(CAPThread*) + 98
8 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
9 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 29:
6 com.apple.qmaster.do 0x318dc460 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
7 com.apple.AECore 0x30623022 aecore::CThread::runThread() + 34
8 com.apple.AECore 0x30620fb9 threadProc(void*) + 17
9 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
10 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 30:
1 com.apple.AECore 0x30623067 aecore::CThread::runThread() + 103
2 com.apple.AECore 0x30620fb9 threadProc(void*) + 17
3 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
4 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 31:
3 com.apple.CoreServices.CarbonCore 0x955b03a7 TSWaitOnConditionTimedRelative + 178
4 com.apple.CoreServices.CarbonCore 0x955b011d TSWaitOnSemaphoreCommon + 490
5 com.apple.CoreServices.CarbonCore 0x955aff2e TSWaitOnSemaphoreRelative + 24
6 com.apple.QuickTimeComponents.component 0x9b54a16a 0x9af5d000 + 6213994
8 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 32:
4 com.apple.FinalCutPro 0x00090525 SyncMetaDataTask::GetNextEvent() + 81
5 com.apple.FinalCutPro 0x00091453 SyncMetaDataTask::Run() + 39
6 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
8 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 33:: jpegdecompress_MPLoop
3 com.apple.QuickTimeComponents.component 0x9b66c467 0x9af5d000 + 7402599
4 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 34:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 35:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 36:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 37:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 38:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 39:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 40:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 41:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 42:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 43:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 44:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 45:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 46:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 47:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 48:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 49:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 50:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 51:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 52:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 53:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 54:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 55:: jpegdecompress_MPLoop
5 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 56:
0 libsystem_kernel.dylib 0x98b2602e __workq_kernreturn + 10
1 libsystem_c.dylib 0x99dfdccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 57 Crashed:
0 libsystem_c.dylib 0x99dd3a40 memmove$VARIANT$sse42 + 131
1 com.aja.kona.videooutput 0x2d206111 MoveFrame(char*, unsigned long, unsigned long, unsigned long, char*, unsigned long, unsigned long, unsigned long, unsigned long) + 154
2 com.aja.kona.videooutput 0x2d217768 CFormatConverter::CConvertFrame(char*, unsigned long, unsigned long, unsigned long, char*, unsigned long, unsigned long, unsigned long) + 4712
3 com.aja.kona.videooutput 0x2d1ee8da APW::VO::Alpine::VideoOutput::CopyDrpToFrame(APW::Alpine::DecompressRecord*, APW::Mux::Alpine::FrameOut*) + 3076
4 com.aja.kona.videooutput 0x2d1eec07 APW::VO::Alpine::VideoOutput::FrameNew(APW::Mux::Alpine::FrameOut*) + 71
5 com.aja.kona.videooutput 0x2d1eed89 APW::VO::Alpine::VideoOutput::FrameNotification(unsigned int, void*) + 51
6 com.aja.kona.muxer 0x2d28cbac APW::Mux::Alpine::Muxer::DoFrameCallbacks(unsigned int, void*) + 452
7 com.aja.kona.muxer 0x2d28b15a APW::Mux::Alpine::Muxer::RunPlaybackAutoCirculateThread() + 544
8 com.aja.kona.muxer 0x2d28c4ff APW::Mux::Alpine::Muxer::Run(int) + 111
9 com.aja.kona.muxer 0x2d28c48a non-virtual thunk to APW::Mux::Alpine::Muxer::Run(int) + 27
10 com.aja.kona.muxer 0x2d245d1d APW::PTA::Thread::RunHelper(void*) + 27
11 libsystem_c.dylib 0x99dfbed9 _pthread_start + 335
12 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 58:
2 com.apple.framework.IOKit 0x91b4723d io_connect_method + 465
3 com.apple.framework.IOKit 0x91af7979 IOConnectCallMethod + 267
4 com.apple.framework.IOKit 0x91af7c70 IOConnectCallScalarMethod + 84
5 com.aja.kona.muxer 0x2d252021 CNTV2MacDriverInterface::WaitForInterrupt(_INTERRUPT_ENUMS_, unsigned int) + 165
6 com.aja.kona.muxer 0x2d268e1f CNTV2Card::WaitForFieldID(NTV2FieldID) + 35
7 com.aja.kona.muxer 0x2d28b626 APW::Mux::Alpine::Muxer::RunPlaybackVbiThread() + 286
8 com.aja.kona.muxer 0x2d28c4e5 APW::Mux::Alpine::Muxer::Run(int) + 85
12 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 59:
6 com.apple.CoreServices.CarbonCore 0x955e2e53 AIOFileThread(void*) + 1019
8 libsystem_c.dylib 0x99dff6de thread_start + 34Thread 60:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 61:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 62:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 63:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 64:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 65:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 66:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 67:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 68:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 69:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 70:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 71:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 72:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 73:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 74:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 75:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 76:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 77:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 78:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 79:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 80:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 81:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 82:
2 libsystem_c.dylib 0x99dff6fe start_wqthread + 30Thread 57 crashed with X86 Thread State (32-bit):
eax: 0x00546000 ebx: 0x00000000 ecx: 0x00000000 edx: 0xffaba000
edi: 0xcc696000 esi: 0x00546000 ebp: 0xb0ec9bf8 esp: 0xb0ec9bf0
ss: 0x00000023 efl: 0x00010246 eip: 0x99dd3a40 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 20Binary Images:
0x1000 – 0x870ffc com.apple.FinalCutPro (7.0.3 – 7.0.3) <41B8A263-80F3-BCC3-FE28-82DE571687A1> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xc2e000 – 0xc31ff7 +KGCore (??? – ???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xc39000 – 0xc39fff com.apple.iokit.dvcomponentglue (2.0.7 – 2.0.7) <1CFA5944-AB33-3A41-B4D2-4A624A514C0D> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xc3d000 – 0xc4cfff com.apple.AERegistration (1.2 – 77) <5D18C47F-6F9E-0C4C-8875-24A14A97186D> /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xc60000 – 0xc67fff com.apple.AEProfiling (1.2 – 22) <43A46C32-8E13-82DD-8AF1-2A40690BF810> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xc71000 – 0xe99ff7 com.apple.prokit (7.2.3 – 1823) <0FEDF2D7-F31A-36F2-91A9-C03877B0CB46> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xfa6000 – 0x1018fef com.apple.ProFX (1.2.3 – 1.2.3) <06B47AC3-9449-A6F0-E189-09D4D1E29A5A> /Library/Application Support/ProApps/*/ProFX.framework/Versions/A/ProFX
0x103a000 – 0x1096ffb com.apple.proapps.MIO (1.0.5 – 509) <3FE469A6-C937-1E44-F79C-9AAA7C902A92> /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x10d3000 – 0x10dcff7 com.apple.finalcutstudio.prometadatasupport (0.6 – 1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x10e4000 – 0x111eff7 com.apple.CoreMediaIOServicesPrivate (52.0 – 3311) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x1139000 – 0x1160ff7 com.apple.CoreMediaPrivate (20.0 – 20.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x1173000 – 0x11a3ff7 com.apple.FWAVCPrivate (52.47 – 47) <8E724EF3-79D6-3B0D-8A57-6E13DA3EACB5> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x11b7000 – 0x11d5fef com.apple.XSKey (1.0.0 – 52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
0x11e4000 – 0x122effb com.apple.CoreMediaIOServices (151.0 – 3232) <0C456E67-311F-3047-9F8E-FB0EAE567DED> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x1250000 – 0x12fdff7 libcrypto.0.9.7.dylib (0.9.7 – compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
0x13a3000 – 0x13e0fff com.apple.vmutils (4.2.1 – 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x2ff7000 – 0x2ff8ff5 +cl_kernels (??? – ???) <57CE9949-8609-483F-AE59-1BA6F95B9BB7> cl_kernels
0x66f5000 – 0x66fdff7 com.apple.proapps.mrcheckpro (1.4 – 398) <400C6D0F-2AC3-F06D-E20C-741BA3D9A558> /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0x6770000 – 0x6772fff libCoreFSCache.dylib (??? – ???) <9E7CBE71-566C-36E9-A49F-C5FF6956D76F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x67b9000 – 0x67bbff3 com.apple.LiveType.component (2.1.4 – 2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x67c1000 – 0x67c3ff7 Motion (729.0.0 – compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x67ea000 – 0x67f6ffb libGPUSupport.dylib (??? – ???) /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0xcf97000 – 0xcfddffb com.apple.motion.component (1.0 – 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0xcfe3000 – 0xcfecff6 libcldcpuengine.dylib (2.0.19 – compatibility 1.0.0) <95A88DC8-E5EE-363F-9275-214D5AB7A2EF> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0xcff3000 – 0xcff7ff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0xe900000 – 0xe964fe2 com.apple.LiveType.framework (2.1.4 – 2.1.4) /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
0xe984000 – 0xea21ff8 com.apple.procore.framework (4.0.2 – 757) /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
0xea61000 – 0xea8eff0 GLRendererFloat (??? – ???) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0xea97000 – 0xeaaeff3 com.apple.FinalCutPro.Plugins.AudioMixer (7.0.3 – 7.0.3) <3C914C5E-510C-EBF8-2FD9-6450CBE8FD46> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0xeab9000 – 0xeabafff com.apple.FinalCutPro.Plugins.Text Window (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0xec7e000 – 0xeca8ff7 com.apple.FinalCutPro.Plugins.AfterEffects (7.0.3 – 7.0.3) <11BBAC1F-38D0-7A1B-0ECD-821729B3AF1B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0xecb0000 – 0xecdafeb com.apple.proapps.ControlSurfaceSupport (2.0 – 68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0xecfb000 – 0xecfbfff libmx.A.dylib (2026.0.0 – compatibility 1.0.0) <859B5BCC-B5D9-370F-8B6C-1E2B242D5DCD> /usr/lib/libmx.A.dylib
0xf5f6000 – 0xf77eff9 GLEngine (??? – ???) <84549EEF-900F-397A-AABC-47DD261F40BE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xf7b5000 – 0xf91fffb libGLProgrammability.dylib (??? – ???) <169ED314-B937-3877-A7D7-4AFB96D8C561> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0xf94e000 – 0xf99affb com.apple.audio.midi.CoreMIDI (1.8 – 42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xf9bd000 – 0xf9c2fff com.apple.FinalCutPro.Plugins.Cache Manager (7.0.3 – 7.0.3) <7E686BFA-2AB3-442B-4203-1D8BA4EA5DA2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0xf9c7000 – 0xf9e1fff com.apple.FinalCutPro.CinemaTools (5.0 – 5.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0xf9ed000 – 0xf9f7ff9 com.apple.FinalCutPro.Plugins.CTHelper (7.0.3 – 7.0.3) <4B1D1B9F-16CB-A86E-E385-B82C12CF7DE9> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0xfb00000 – 0xfd9cff3 com.apple.ATIRadeonX3000GLDriver (7.32.12 – 7.3.2) <86BEF6D7-D130-36AB-8939-5AB20C0681FE> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLDriver
0xfdd1000 – 0xfdd9fff com.apple.FinalCutPro.Plugins.Effect Builder (7.0.3 – 7.0.3) <47BE0505-F602-9535-8684-EAF732016E93> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0xfdde000 – 0xfde9ffe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport (7.0.3 – 7.0.3) <41DA2698-9984-6241-130D-AACA55C647B4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0xfdf2000 – 0xfdf5ffc com.apple.FinalCutPro.Plugins.FinalTouchExport (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0xff00000 – 0xffd8ff2 com.apple.FinalCutPro.Plugins.Browser (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0xfff6000 – 0xfffafff com.apple.FinalCutPro.Plugins.LayerFileReader (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0x10000000 – 0x10060fef com.apple.proapps.AudioMixEngine (2.0 – 68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x22011000 – 0x22037ff7 com.apple.FinalCutPro.Plugins.EditTape (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0x22046000 – 0x220a1ff5 com.apple.FinalCutPro.Plugins.EDL Export (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0x220b6000 – 0x220e9ff7 com.apple.FinalCutPro.Plugins.FCS Engine (7.0.3 – 7.0.3) <1D178B47-1E72-47D8-D52D-EE1590B4F5AA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0x220f3000 – 0x22104ff7 com.apple.FinalCutPro.Plugins.FilterCustomEd (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0x2210a000 – 0x2211fffb com.apple.FinalCutPro.Plugins.FilterViewer (7.0.3 – 7.0.3) <8DA6D80C-B3A2-B2FF-6F2F-A44122508E27> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0x22125000 – 0x22143fea com.apple.FinalCutPro.Plugins.Flash (7.0.3 – 7.0.3) <2CEAAEE1-4EF6-7180-2CAA-6DDE45E667DB> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0x2214f000 – 0x2215cffb com.apple.FinalCutPro.Plugins.GenViewer (7.0.3 – 7.0.3) <724F50F6-7A13-D6C3-B7CB-63CB23829F27> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0x22162000 – 0x221aeff3 com.apple.FinalCutPro.Plugins.Media Manager (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0x221b8000 – 0x221caff0 com.apple.FinalCutPro.Plugins.MolokiniSupport (7.0.3 – 7.0.3) <85EAB333-1140-0657-27FF-B21F7DAEB40E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0x221d9000 – 0x221edfff com.apple.FinalCutPro.Frameworks.MolokiniTranslation (1.0 – 1.0) <7A59B9CD-7B44-2258-E79B-FCC5F9CAB309> /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0x221fb000 – 0x2222dffb com.apple.FinalCutPro.Plugins.Motion Viewer (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0x2223e000 – 0x22259ff3 com.apple.FinalCutPro.Plugins.Movie Analyzer (7.0.3 – 7.0.3) <82EA8688-294B-3739-E719-09275DD966A7> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0x22268000 – 0x2227effb com.apple.FinalCutPro.Plugins.Movie Viewer (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0x2228a000 – 0x2228efff com.apple.FinalCutPro.Plugins.NuggetExport (7.0.3 – 7.0.3) <83A2CB39-EA91-DB85-E458-DDA09C4F9793> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0x22293000 – 0x2234cfe7 com.apple.FinalCutPro.Plugins.OMF Audio Export (7.0.3 – 7.0.3) <1515F152-5847-223C-E5FE-CA894EDF121C> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0x2235f000 – 0x22367ffb com.apple.FinalCutPro.Plugins.Perf Analyzer (7.0.3 – 7.0.3) <1E04DC98-638A-CB1E-C04E-3B0C0E3CD199> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0x2236c000 – 0x22381ffb com.apple.FinalCutPro.Plugins.ProAppsIntegration (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0x22391000 – 0x2239eff7 com.apple.FinalCutPro.Plugins.Pulldown Support (7.0.3 – 7.0.3) <555A8A21-3312-5CA8-FDA3-433F997DA91E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0x223a6000 – 0x223e5fef com.apple.FinalCutPro.Plugins.QTM Reader (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0x223f2000 – 0x223faff3 com.apple.FinalCutPro.Plugins.QuickView (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0x223ff000 – 0x2240fffe com.apple.FinalCutPro.Plugins.Relink Media (7.0.3 – 7.0.3) <67805834-C6B2-061D-7581-E3D7835DB779> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0x22416000 – 0x224afff2 com.apple.FinalCutPro.Plugins.Timeline Editor (7.0.3 – 7.0.3) <1870750B-B6C6-9132-E680-CA9338AE23D6> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0x224be000 – 0x224cffff com.apple.FinalCutPro.Plugins.Transcoder (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0x224d9000 – 0x224ebfff com.apple.FinalCutPro.Plugins.Transition Viewer (7.0.3 – 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0x224f1000 – 0x22506ff3 com.apple.FinalCutPro.Plugins.Trimming (7.0.3 – 7.0.3) <449089A2-91B0-4CC7-2A2C-0DD44827F041> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0x
