Activity › Forums › Apple Final Cut Pro Legacy › FCP After Effects 10-Bit
Posted by Fred on January 22, 2007 at 9:29 pmI’m working on an Animation for TV Broadcast.
Wes Plate replied 19 years, 8 months ago 6 Members · 5 Replies -
Shane Ross
January 22, 2007 at 9:31 pmDo the color correction in AE if you are working 10-bit. That bug in FCP apparently still hasn’t been fixed.
Sounds like a good workflow to me.
Shane
Littlefrog Post
http://www.lfhd.net -
Ed Dooley
January 22, 2007 at 9:45 pmNot sure if this will affect what you’re doing (or planning), since you’ll be using Animation,
but Mike over at HDForIndies:
https://www.hdforindies.com/2006/06/after-effects-stuff-workflow-tips-and.html
has a thread about some AE 10 bit, export from QT issues.
Ed -
Jeremy Garchow
January 23, 2007 at 1:17 amI am a little confused about you workflow, but you should know that you cannot edit in FCP in real time with the sequence set to animation. I do not see any image degradation when doing cc in FCP in 10 bit, but then again, I don’t do animation so perhaps your standards are different. I don’t see why you need to to AE then back to FCP, then back to AE, then back to FCP. It seems to me you can cut out a few steps there.
Jeremy
Bret Williams
January 23, 2007 at 7:06 am[FooKai] “All the animation exported as Quicktime files at the Animation Codec.
Wes Plate
January 23, 2007 at 3:25 pmIf you want your FCP clips to be separate layers in After Effects– sounds like it since you’re adding effects and color correcting– consider Automatic Duck’s Pro Import AE plug-in for translating the FCP timeline to After Effects. https://www.automaticduck.com/piae/
The plug-in will save you loads of time and hassle.
— Wes Plate
Automatic Duck
