Activity Forums Adobe After Effects FCP-AE CS3-FCP
  • FCP-AE CS3-FCP
    Posted by Olivier Aubut on February 11, 2008 at 5:03 pm
    I just upgraded from AE 7.0 to AE CS3.
    In 7.0 there was an option in the interpret footage window: “Expand ITU-R601 Luma Levels” I was using that option to “correct” or minimize the color shift from using dvcprohd out of FCP.
    Does anyone know where that option is in CS3 or did they rename it?
    Does anyone have another option for the FCP-AE-FCP workflow. To eliminate or minimize the YCbCr to RGB problem?
    By the way I’m using FCP 5.1.4
    Thank you
    Olivier Aubut replied 18 years, 6 months ago 3 Members · 3 Replies
  • Ross Gerbasi
    February 11, 2008 at 7:12 pm
    Not sure how much this will help, but you could try this
    https://www.popcornisland.com/downloads
    To move from final cut into after effects. I would be interested to know how it works with FC 5.1.4. Honestly I don’t know much about the problem your having… just know this should get your work into AE from final cut.
    Also if there are any changes I could make to this to speed up your process that would correct your color issues, lemme know!
    -ross
  • Darby Edelen
    February 11, 2008 at 7:26 pm
    [Olivier Aubut] “Does anyone have another option for the FCP-AE-FCP workflow. To eliminate or minimize the YCbCr to RGB problem? “
    You’ll want to use the new color management workflow in AE CS3. Check this PDF out:
    https://www.adobe.com/go/learn_ae_colormanagementpaper
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Olivier Aubut
    February 11, 2008 at 7:37 pm
    Thanks Darby, exactly what I needed.
    Ross – Doesn’t solve my problem, but it will help me save a LOT of time.
    thanks a lot guys
    Olivier
