Activity Forums Apple Final Cut Pro Legacy FCP adding SHIFT FIELDS filter automatically when I cut and paste a sequence
  • FCP adding SHIFT FIELDS filter automatically when I cut and paste a sequence
    Posted by Amanda Cusanelli on October 29, 2010 at 3:12 pm
    Every time I cut and paste tracks from one sequence to another, FCP automatically adds a SHIFT FIELDS filter. How do I stop this? Im working with over 20 layers between the video and audio. With this filter, I have to delete from each cut and each layer… causing rendering to be a nightmare.
    FCP 07
    HD footage
    All suggestions will be helpful!!! Thank you
    Michael Gissing replied 15 years, 10 months ago 3 Members · 3 Replies
  • Zak Ray
    October 29, 2010 at 4:28 pm
    Make sure your sequence settings are matching. FCP can do this when you’re copying from a lower-field sequence to an upper or vice-versa.
  • Amanda Cusanelli
    October 29, 2010 at 5:53 pm
    I have already done this and it continues to happen. Any other ideas?
  • Michael Gissing
    October 29, 2010 at 10:21 pm
    FCP will add the shift fields filter if the clip settings do not match the sequence settings. Check the field order of your source footage and the settings in the sequence.
    My guess is your clips may be set incorrectly. Also are you sure that you don’t need the filter? Are you monitoring on an external monitor that shows interlace? I have not had an experience where FCP got it wrong so I suspect there is a problem which should be resolved.
