Activity › Forums › Apple Final Cut Pro Legacy › FCP add angle to multiclip problem
  • FCP add angle to multiclip problem
    Posted by Charalampos Tyligadas on September 29, 2010 at 1:35 pm
    So, my problem is this: I have been trying to add angles to multiclips, but for some reason this won’t happen. Even though I can work around this issue by making a new multiclip combining the existing multiclip and the new angle, I would like to know why the drag-and-drop “add angle to multiclip” system doesn’t work for me. The footage I use are all the exact same format, so that isn’t the problem. As a test, i create a new project and do the exact same thing with the exact same files, and it works–so that makes me think it might be a settings issue in my main project. Any ideas as to why this happens?
    Charalampos Tyligadas replied 15 years, 12 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    September 29, 2010 at 6:12 pm
    Might be some sort of corruption in the project file… try creating a new project file, and select all from the original file’s browser and copy it. Paste it all in the new file and see if there’s improvement. There are no settings I know of that would change this particular behavior.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Charalampos Tyligadas
    October 4, 2010 at 12:29 pm
    Hey Jerry,
    That did the trick, thanks alot!
    “I believe in sunshine, fresh air, spinach, applesauce, laughter, buttermilk, babies, bombazine and chiffon.”
