Activity Forums Apple Final Cut Pro Legacy FCP 7/Quicktime X Aspect Ratio Issues.
  • FCP 7/Quicktime X Aspect Ratio Issues.
    Posted by Lucas Way on April 18, 2010 at 3:02 pm
    Hi all.
    So basically, after upgrading to Snow Leopard (and in turn Quicktime X) I’m havign some very wierd aspect ratio issues in FCP.
    So I have to make a showreel of previous projects of mine & after importing them into FCP 7 things aren’t going right.
    The films were all exported as PAL 16:9 QT files from FCP6, and when I open them in QT7 they look their normal 16:9 self… however upon opening them in Quicktime X they are stretched horizontally so that they are super widescreen, distorting the image in the process.
    This wouldn’t normally bother me as I can easily watch them on QT7
    BUT
    When importing those files into FCP7 they’re having the same issue, showing up on the preview screens as this stretched super-widescreen image, which of course, I do not want.
    I’ve looked in the video properties on QT7 (a feature stupidly missing from X) & adjusted them to be 16:9 dimensions, even after doing that, they still show up as super widescreen in QTX and FCP7.
    [Does FCP7 use QTX as it’s underlying video format like FCP6 used QT7?]
    Please can anyone help me out on this? This showreel is due very soon as at the moment I can’t even start since the files are such a weird aspect ratio.
    John Fishback
    replied 16 years, 5 months ago
    2 Members · 1 Reply
  • John Fishback
    April 18, 2010 at 4:12 pm
    In FCP in the Motion tab check if the distort settings are causing the problem. If so, you can use Remove or Paste Attributes to fix.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
