Activity Forums Apple Final Cut Pro Legacy FCP 7.0.3 Multicam problem after adding transitions
  • FCP 7.0.3 Multicam problem after adding transitions
    Posted by David Stembridge on May 1, 2012 at 8:01 pm
    I’ve been using multicam for year, was working on a project tonight, performance with 2 camera angles. Video tracks in great shape; after editing the 1 hour sequence, I did a little color correction, and rendered, then added dissolves to groups of edits.
    Playing back after rendering there are jumps around the dissolves. I tested a very short sample, and exported, and there now appears to be a syncing issue. If I add both angles to a time line, and loew the opacity of the top angle, any where I scan, the angles are in sync, tightly.
    Could my work flow be causing this?
    (the first several dissolves are fine; watch through, and you’ll see some of the problem I’ve having)
    multicam issues
    Jerry Hofmann replied 14 years, 4 months ago 2 Members · 1 Reply
