Activity › Forums › Apple Final Cut Pro Legacy › FCP 7.0.2 is broken?
Posted by Garrett Gibbons on April 13, 2010 at 1:17 amI’ve been having the well-commented-on problem with ctrl-G (close gap) that seems to have been broken with this latest update to FCP 7.0.2, but I’m also having a major problem with audio that I’m not seeing elsewhere.
When an AIFF file is in the timeline, the app will freeze as soon as I hit play. This has happened in several different projects since 7.0.2 was updated. Occasionally, I have restarted the computer and the problem has good away for a few minutes, only to return without any noticeable change in conditions. I can scrub through the footage and the audio plays and there are no problems.
Has anyone else seen this?
Jon Willis replied 16 years, 5 months ago 6 Members · 8 Replies -
David Roth weiss
April 13, 2010 at 1:24 amDid you update to FCS3 over the top of FCS2, or did you you do a fresh install from the ground up?
If it’s the former, then I’m not surprised by any issues, and neither should you. If it was a clean install then that’s another matter.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Garrett Gibbons
April 13, 2010 at 1:39 amWell, I don’t think it’s possible to update 7.0.2 from the ground up. I did install 7.0 clean, then updated to 7.0.1 then 7.0.2. I didn’t have any such issues until this recent Pro Apps update.
David Roth weiss
April 13, 2010 at 1:56 am[Garrett Gibbons] “I did install 7.0 clean, then updated to 7.0.1 then 7.0.2. I didn’t have any such issues until this recent Pro Apps update.
“Okay, you passed the test Garret.
You’re one of very few people reporting problems who actually have done a clean install. It does kinda point to a possible issue with 7.0.2, though I must say, there hasn’t been much complaining here.
David Roth Weiss
Garrett Gibbons
April 13, 2010 at 2:41 amIndeed. Here is a thread about the broken “close gap” feature when clips have differing numbers of audio tracks: https://forums.creativecow.net/thread/8/1080723
Jonathan Dortch
April 13, 2010 at 6:21 amHaving the exact same problem. Will only close the first gap in the timeline, then every following gap. It won’t close the gap at the playhead with the shortcut or with a right click command. Just happened after the ProApps / 7.0.2 update. It does seem to correct problem if you eliminate any multi-track audio before the gap (e.g. only 2 layers of audio). Any more news on this? I use close gap religiously — this is beyond annoying…
JONATHAN DORTCH
Mark Maness
April 13, 2010 at 3:24 pmEver heard the phrase… “Fix one, break two.”
This seems to be the case every time there is an update to ANY software package.
The lesson here… Clone your OS drive before applying ANY updates, so that you can revert back to a safe version if problems arise.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
C david Miller
April 14, 2010 at 6:54 amWell it works just fine on my 7.0.2 version, but then again,am using a G5…….shhhhhh before David flames me again.
Dave
Stay Connected – It’s Comcastic -
Jon Willis
April 16, 2010 at 8:38 amI’m have a problem with 7.0.2 now.
When putting titles over a multi-cam edit the titles keep resizing themselves when moving from camera to camera. If i “mute” the video track, the titles stay at the correct size.Has anyone else had a problem like this? I’ve searched but found nothing.
The client is coming in 20 minutes…
How i wish I’d backed up the system!
Cheers.
