Activity Forums Apple Final Cut Pro Legacy FCP 7.0.1 Multiclip editing with 4 sources?
  • FCP 7.0.1 Multiclip editing with 4 sources?
    Posted by Brian Lettieri on March 21, 2010 at 3:49 am
    We just installed FCP 7.0.1 and Kona3 7.1 and have set up a 4 camera multi cam edit. When the 4 sources are viewed in the viewer there is an almost 2 second delay to the program monitor. However when only 3 of the sources are created in multicam the monitor timing is perfect. Has anyone ran into this problem and does anyone have a fix? Thank you.
    Brian Lettieri replied 16 years, 6 months ago 2 Members · 5 Replies
  • Shane Ross
    March 21, 2010 at 5:18 am
    What hard drive is this footage stored on? And what codec is the footage? Important details…
    Shane
  • Brian Lettieri
    March 21, 2010 at 5:54 am
    Shane we have a San for storage and the codec’s are DVCProHD720.
  • Shane Ross
    March 21, 2010 at 6:04 am
    Connected via fiber? Gig Ethernet? Is it rated fro video?
    Have you run a drive test on it (the AJA one or Decklink one) to see what read-write speeds it gets?
    Shane
  • Brian Lettieri
    March 21, 2010 at 6:16 am
    Shane
    We are fiber connected. FYI last week using G5’s and FCP 6.0.2 it worked perfectly. I just created a multiclip using 4 streams of SD [DVCPro SD 525] and it worked perfectly.
    Brian
  • Brian Lettieri
    March 21, 2010 at 4:46 pm
    We found the RT settings were in Dynamic which seems to have caused the problems. We changed settings to Unlimited RT with Playback VideoQuality = High and Playback Frame Rates = Full fixed the problems. Just the opposite of the settings for FCP 6.x. Thanks for your help Shane!
