Activity Forums Apple Final Cut Pro Legacy FCP 7 XDCAM EX woes…still…
  • FCP 7 XDCAM EX woes…still…
    Posted by Jim Blokland on November 1, 2010 at 2:04 am
    Hi fellow COW-ers:
    I”m looking for advice. Here’s the symptoms of my situation:
    – cutting XDCAM EX on FCP 7 ProRes 422 timeline, with MX02 mini on Westmere OCTO 14 GB RAM
    – getting lots of random crashes
    – often seems to be connected to disk access, ie., move the cursor, disk accessing, CRASH
    – when in trim mode, sometimes record window will flicker between frames (a la Max Headroom) before a crash, or the Matrox will display a ‘fuzzy’ green screen of scan lines, precipitating a crash
    – not sure if it’s the Matrox drivers, the fact that I’m running the entire feature off one 2 TB internal drive (maybe I should split up the media between 2 drives..?), the system itself, or ??
    So please, it would be a great help in my troubleshooting process, if some user experience that echoes mine could point me in the right direction to get my system back to being bullet-proof. Or at least, not crashing every minute when the client is here.
    Right now, I’m loading up a clean system install on a bare drive, with FCP 7 and the latest Matrox drivers, to at least clarify if the issue is somewhere in that configuration…
    All real-world advice welcome.
    Best, JIM.
    Snow Leopard 10.6.4
    Mac Pro Octo Westmere
    14 GB RAM
    ATI Radeon 5870
    Matrox MX02 Mini
    Seritek 4 TB RAID
    AVID MEDIA COMPOSER 5 // FCS3
    Rick Moore replied 15 years, 3 months ago 11 Members · 36 Replies
  • 36 Replies
  • Steve Connor
    November 1, 2010 at 7:14 am
    Have you tried turning off thumbnails in the timeline, this stopped the crashes for me.
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Rafael Amador
    November 1, 2010 at 10:05 am
    Hi Jim,
    I would start by making a bit of system cleaning: Permisions, rebuilding directories, etc.
    rafael
    http://www.nagavideo.com
  • Jim Blokland
    November 1, 2010 at 7:24 pm
    Hi guys:
    Thanks for your responses so far. I have tried turning off thumbnails, doesn’t seem to make a big difference. I have also repaired permissions, no difference. Is there software for rebuilding directories you can point me to?
    Last night I did a clean install of Snow Leopard and FCP and the Matrox 2.0 driver on a bare drive. Worked okay at first, but then it began to crash too. 4 times within a half-hour. The sequences are only 20 minutes long maximum, and the project files are only about 30 MB, so that shouldn’t be the issue.
    I’m going to try splitting up the media onto two drives next, see what happens. I’ll post back then.
    Any other advice most welcome.
    Best, JIM.
    Snow Leopard 10.6.4
    14 GB RAM
    ATI Radeon 5870
    Matrox MX02 Mini
    Seritek 4 TB RAID
  • Andrew Gurney
    November 1, 2010 at 8:45 pm
    I’m currently working on a 7 camera series with XDCAM EX footage. We had significant problems with System Crashes on all 4 of our systems using FCP 7.
    Our solution was to create offline versions of all of our footage using the Apple ProRes 422 Proxy codec.
    If you can afford the hard drive space I would recommend doing that. It’s a fairly straight forward process of simply media managing the Source Folder and recompressing with the new codec. Then you just reconnect your source folder to the new files. Even our multi-clips were updated correctly, it was almost too easy. I haven’t had a system crash since we did this 3 weeks ago.
    Took a full day to do 1 TB of footage and it required another TB of hard drive space for the proxies, so we usually do an Episode over the weekend.
  • Jim Blokland
    November 1, 2010 at 8:54 pm
    Hi Andrew:
    Thanks so much for this info. Finally, something that makes sense to me. I’m working on a doc feature, with 80+ hours of material — but it will be worth it to not have to deal with the incessant crashes.
    I’ll post back when I have (hopefully good) news.
    PS: Are you pretty happy with the look of the proxy ProRes? Good enough for screenings on decent-sized screens?
    Best, JIM.
    Snow Leopard 10.6.4
    14 GB RAM
    ATI Radeon 5870
    Matrox MX02 Mini
    Seritek 4 TB RAID
  • Sam Cole
    November 1, 2010 at 11:16 pm
    When I reported similar issues on this forum I was told by the ‘Apple Cult’ that it was my system and should get a ‘proper’ system integrator as “no one else reports these problems”.
    Then they told me it was “because I was ‘down under’ and everything worked in reverse”. Are you in Aussieland? Are you using the same ‘system integrator’ as I am?
    Well after it was all looked at by numerous engineers it was determined that it is a FCP 7/snow leopard bug with memory management and codec.
    I would love to stand behind one of these ‘Apple Cult Members’ when their system crashes to see what they say then. Most of their pictures are at the top of this forum.
    My boss warned me about them and I didn’t listen.
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
  • Steve Connor
    November 1, 2010 at 11:57 pm
    Not sure that rant is particularly helpful to the OP.
    Steve Connor
  • Jim Blokland
    November 2, 2010 at 3:54 am
    Hey Sam:
    Thanks for your note. I understand the frustration. Especially when it seems like you’re the only one having the issue. I hope Apple fixes this in a future software iteration. I’m not a huge fan of XDCAM to begin with, but I’m sure I’ll be seeing more footage shot with that codec in future — and I’d like to know that my brand-spanking new Octo can deal with it without having to transcode to ProRes every time.
    Best, JIM.
    Snow Leopard 10.6.4
    14 GB RAM
    ATI Radeon 5870
    Matrox MX02 Mini
    Seritek 4 TB RAID
  • Sam Cole
    November 2, 2010 at 11:33 pm
    [Steve Connor] “Not sure that rant is particularly helpful to the OP.”
    It wasn’t a rant but FACT.
    And if you read it correctly you will see it WAS a help as the OP no longer has to keep stripping his system down to fix his problem; he just has to wait for a fix which from what I understand won’t be until the next version of FCP which is a major rewrite (another way of saying ‘awesome’).
    Sam Cole
    FCP, Avid, Adobe
    Sydney, Australia
  • Sam Cole
    November 2, 2010 at 11:42 pm
    [Jim Blokland] “I understand the frustration”
    Hey Jim – the frustration comes from a. Apple not fessin’ up regarding the issue and b. the ‘apple clan’ always leaping to their defence to gain brownie points from an organisation that doesn’t keep score.
    Even more frustrating is when Sony bring out a native method of dealing with XDCAM (cinemon) and while you can bring the MP4 files directly into the timeline, applying filters (eg. green screen) is almost unworkable because the controls are so sluggish!
    FCP 8, 8 x 8 = 64, now that is a good number and all our problems will be solved (for a little while).
    Sam Cole
    FCP, Avid, Adobe
    Sydney, Australia
Page 1 of 4
