Activity Forums Apple Final Cut Pro Legacy FCP 7 XDCAM EX timeline weirdness
  • FCP 7 XDCAM EX timeline weirdness
    Posted by Jim Blokland on October 12, 2010 at 12:10 pm
    Hello:
    I am experiencing a quirk in playback, where if I scale the timeline up or down during playback of an XDCAM EX 24p sequence, I get a spinning beachball and quite a delay — and then the timeline eventually resizes and catches up to the playback position. Also, sometimes the beachball occurs when I press stop — the sequence keeps playing for awhile, with the beachball spinning, then eventually stops.
    I’m working with an MX02 mini for playout, on a Westmere Octo 2.4 with 14 GBs of RAM and a 5870 video card, with all the latest/greatest software/drivers. I’ve tried the same thing on a DV sequence and it doesn’t exhibit any of these issues — with same hardware configuration.
    Any ideas what I can do to improve the situation? Kind of a drag when you’re with a client and you hit stop and FCP keeps playing…
    Thanks in advance.
    Best, JIM.
    Snow Leopard 10.6.4
    Mac Pro Octo Westmere
    14 GB RAM
    ATI Radeon 5870
    Matrox MX02 Mini
    Seritek 4 TB RAID
    AVID MEDIA COMPOSER 5 // FCS3
    Jim Blokland replied 15 years, 11 months ago 2 Members · 2 Replies
  • John Kaley
    October 12, 2010 at 10:30 pm
    Make sure the Raid drivers/firmware is up to date. You can also try to hide FCP, then unhide and see if your performance comes back.
  • Jim Blokland
    October 13, 2010 at 1:22 am
    Hi, thanks for your response.
    I’m starting to think it’s an issue with the Matrox MX02 mini, because when I set the playback option to none — not using the MX02 — the timeline functions perfectly. So somehow, the Matrox may be causing the computer to bog down. I’ve posted on the Matrox COW forum to see if I can get any advice there.
    Thanks again.
    Best, JIM.
    Snow Leopard 10.6.4
    14 GB RAM
    ATI Radeon 5870
    Matrox MX02 Mini
    Seritek 4 TB RAID
