Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Will Not Launch
  • FCP 7 Will Not Launch
    Posted by Andrea Christian on January 18, 2014 at 4:46 am
    I installed FCP 7 on an up-to-date Maverick OS. While the splash window is up loading plug-ins, it crashes each time on AUPitch.
    I’ve removed my media, plug-ins and effects in case any were corrupt, I’ve worked with Digital Rebellion’s Plugin Manager and Project Repair with no luck.
    I’m a stumped designer who primarily works in AE/Ai/PS. It’s been a while since I’ve worked with FCP much less troubleshooting on newer iOS. I appreciate any insight you can lend, I’ve read a large amount of the other posts and can’t find a solution.
    Jon Chappell replied 12 years, 8 months ago 2 Members · 3 Replies
  • Jon Chappell
    January 18, 2014 at 6:40 am
    Try running QuickFix or Housekeeper in Pro Maintenance Tools as they clear the Audio Unit cache.
    My software:
    Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
    Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
    More tools…
  • Andrea Christian
    January 18, 2014 at 10:30 pm
    Thank you, Jon!
    I thought that was going to be the golden ticket. Unfortunately, the launch crash happened at the same time of the splash window. Also ran Corrupt Clip Finder with no progress.
  • Jon Chappell
    January 18, 2014 at 11:31 pm
    I’d normally recommend disabling plugins that cause crashes, however AUPitch is a system Audio Unit. It might be a sign of wider problems with your system, but since it’s sound-related, one thing to try is to look at Audio MIDI Setup in /Applications/Utilities. I haven’t had any specific problems with FCP 7 there but I always have to disable Adobe Prelude there to get Pro Tools to operate properly.
    My software:
    More tools…
