Activity Forums Apple Final Cut Pro Legacy FCP 7 Voice Over tool = Spinning ball of death
  • FCP 7 Voice Over tool = Spinning ball of death
    Posted by Adam Phillips on August 1, 2011 at 9:52 pm
    Using FCP 7 to record a Voice Over except when I select the VO tool FCP just locks up with the ball of death.
    I use the VO tool quite regularly and have never encountered this problem before. The only difference in my laptop is that I updated to Lion. Has anyone else encountered the same problem and that know a way around it.
    Thanks in advance,
    Adam
    Mac Book Pro
    Mac OS X 10.7
    2.53 GHz
    4 GB Memory
    Kerry Bell replied 14 years, 8 months ago 5 Members · 4 Replies
  • Michael Gissing
    August 1, 2011 at 11:03 pm
    [Adam Phillips] “The only difference in my laptop is that I updated to Lion. Has anyone else encountered the same problem and that know a way around it.”
    Changing an OS is fairly major and none of the wise heads here recommends any sort of major system changes without first making a clone of your system drive. If you did that you have a way back. If not then you have at least warned others of something that Lion has likely broken.
    Lion has a lot of major changes under the hood, most of those have nothing to do with FCP 7 which for Apple is now legacy software and will not be supported by any bug fixes or upgrades. Apart from Repairing permissions and trashing preferences, there is not a lot to advise apart from rolling back to your previous working system from your clone.
  • Tim Newton
    September 3, 2011 at 12:55 pm
    Yes – same thing for me – updated to Lion and same error everytime. Is there a fix?
  • Julian Clode
    November 11, 2011 at 8:17 pm
    We are currently in the middle of an extensive roll out of FCP7 on Lion. There have been a lot of reports about the Voice Over Tool crashing. We have found this seems to relate to the audio being set to 48Khz. If you change it to record 44Khz the VO tool becomes stable.
  • Kerry Bell
    December 25, 2011 at 6:00 pm
    My work around for
    using the VO with FCP7 in Lion:
    1. close all sequences
    2. open VO tool
    3. be sure it is set for 44100
    good to go.
    Bell Video Productions
    San Diego, CA
    619-540-6008
