FCP 7, uses only 1 core when rendering/comprssor
Hi I am FCP user since Version 3
I have a P6T Deluxe V1, and have tried on a P6t SE to use FCP and have more then one core working.
It has 6 gigs of ram, a 920 I7 chip,and I have tryed this with a 4850,and 4870 video card.
If I render the time line or export using compressor, or exporte using quicktime conversion. FCP will use 100% I.E. 1 core and the trancoder or transcoderx will use 25% of a second core. If I set qmaster to use more then 1 core it will crash on all but 2 or 3 segment, thouse will render but are useless. If I set it to 1 core and add my laptop it will finish but the segments from my macbook show as unrendered.If I only use 1 istance it will work, but takes forever.
If I make a managed mode with Qadministrator, and look at the propites of my hackintosh, it will show 8x3ghgz Unkown.
In short my mac book will render somthing in 8 hours, and if I use my hackintosh it will render in 37 hours. I need this to work.
Please help.
