Activity › Forums › VEGAS Pro › FCP 7 to Sony Vegas
  • FCP 7 to Sony Vegas
    Posted by Steve Jinks on December 12, 2011 at 5:03 pm
    Hi
    Does anyone know if you can:
    (succesfully) import FCP7 XML’s into Sony Vegas (windows) and will FCP Markers be included?
    Is there any way Vegas can work natively with quicktime mov files? (on windows)
    Any help including links to how to’s or tutorials would be much apprecieated
    Many thanks in advance
    Steve
    John Rofrano replied 14 years, 9 months ago 5 Members · 16 Replies
  • 16 Replies
  • Steve Rhoden
    December 12, 2011 at 5:18 pm
    Is there any way Vegas can work natively with quicktime mov files? (on windows)…….
    Yes it does.
    As for the other question of FCP7 XML import, im not sure if that
    will work well at all.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Steve Jinks
    December 12, 2011 at 5:30 pm
    Thanks Steve. Is it simply a case of installing quicktime for windows or do you have to get hold of some kind of plugin?
  • John Rofrano
    December 12, 2011 at 5:49 pm
    [Steve Jinks] ” Is it simply a case of installing quicktime for windows or do you have to get hold of some kind of plugin?”
    Yes, just install QuickTime for Windows. That’s what’s needed to process QuickTime files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Jinks
    December 12, 2011 at 6:05 pm
    Many thanks – Im not used to windows.
  • Ken Mitchell
    December 12, 2011 at 7:55 pm
    Just make sure that they don’t give you Apple HDV or Apple intermediate codec video files… Those don’t exist on a PC. Ask for PRoRes files.
  • Steve Jinks
    December 13, 2011 at 2:22 pm
    Thanks – I’m trying to transfer my FCP project to someone who uses Vegas (hence my ignorance) the footage was shot on DV so I assume mov files would be ok?
  • Mike Kujbida
    December 13, 2011 at 4:29 pm
    I deal with FCP users on a regular basis and have gotten anything from SD mov files to HD ProRes files.
    Pro 10 has never had a problem with any of them.
  • Ken Mitchell
    December 13, 2011 at 6:58 pm
    If you are editing your sequence in dvcpro 480 lines interlaced I would suggest you export a dvcpro.mov.720×480 interlaced., A prores file would probably end up being 486 interlaced and screw up your interlacing.. so if you do a prores file it has to match your sequence.
  • Mike Kujbida
    December 13, 2011 at 8:12 pm
    I’ve dropped 720 x 486 files on a Vegas timeline (animations – uncompressed AVI) and never had any interlace problems.
  • Ken Mitchell
    December 13, 2011 at 10:59 pm
    you should not have problems with animations if they are progressive. You will only have problems with interlaced video going from 480 to 486 or 486 to 480. Progressive animation will not have this issue since it does not have interlacing.
