Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 to FCP7 Recording
  • FCP 7 to FCP7 Recording
    Posted by Ehtesham khan Ham on May 28, 2015 at 4:39 pm
    Hello,
    I’ve a question regarding live recording of an FCP7 timeline sequence to another computers Timeline.
    Can we make 1st FCP timeline sequence (Source) and other computer’s FCP Capture window (say a macbook pro) as TARGET… ?
    Without using a deck or a conversion HUB..
    Just like live recording through a source (composite or firewire) ??
    ET
    Michael Gissing replied 11 years, 4 months ago 5 Members · 6 Replies
  • Shane Ross
    May 28, 2015 at 5:23 pm
    The only way to do this, and I have done this…is for both computers to have capture hardware…or “IO” hardware. Both need to have an AJA or Decklink or Matrox device for capture and output.
    Shane
    Little Frog Post
  • David Roth weiss
    May 28, 2015 at 5:26 pm
    It can be done via FireWire or preferably FireWire 800.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Ehtesham khan Ham
    May 28, 2015 at 7:20 pm
    Thanks David for your reply..
    If it can be done through firewire 800 port, What would be the process..
    I’ve got a macbook pro… and an 8core macpro tower with decklink 4k card installed..
    I would really appreciate it..
    Ehtesham
  • Shane Ross
    May 28, 2015 at 7:35 pm
    Firewire only works if the footage and sequence settings are DV, DVCPRO HD, or HDV. Those are the only formats supported.
    Oh, in fact, you can only output HDV via firewire if you have FCP prep it. Sorry, it’s been so long, I forget the process. But unlike DV and DVCPRO HD…HDV cannot be played out in real time…a rendering/prepping process had to happen, and then you would click OK to output it. But that only works to HDV cameras or decks.
    Firewire doesn’t work with ProRes.
    Shane
    Little Frog Post
  • Tom Matthies
    May 28, 2015 at 8:27 pm
    HDV-Conforming before output.
    Not my monkeys. Not my circus.
  • Michael Gissing
    May 29, 2015 at 2:48 am
    What Dave said. Quicker to export a quicktime from the source sequence and drop it on the other computers timeline. No need for fancy hardware interfacing or using dud codecs like DV and it would likely be the quickest too.
