Activity Forums Apple Final Cut Pro Legacy Fcp 7 timeline issues
  • Fcp 7 timeline issues
    Posted by Baba brouk Peters on April 2, 2014 at 8:25 pm
    We are editing a feature doc in FCP 7 – many different codecs and cameras which led us to accidentally form the full timeline in 25fps – we have since adjusted it to 23.98 but are now running into a plethora of other issues – among which is our audio is mysteriously looping. I need export an OMF and a low res MOV of the entire timleine with timecode by tomorrow morninig
    Shane Ross replied 12 years, 5 months ago 2 Members · 1 Reply
  • Shane Ross
    April 2, 2014 at 9:25 pm
    What are the sequence settings now? Besides frame rate…what “codec?” Is all of your footage in an editing codec, like ProRes, DVCPRO HD, XDCAM…or do you have things like MP4 or H.264 in the sequence?
    What are the settings for your audio? FCP craves 48Khz 16 bit stereo…either AIFF or Broadcast WAV files.
    Did you fix all the gaps that comes when you paste one frame rate into another frame rate sequence?
    Shane
    Little Frog Post
