Activity › Forums › Apple Final Cut Pro › FCP 7 Timeline into Compressor 4
  • FCP 7 Timeline into Compressor 4
    Posted by Adam Berch on October 27, 2015 at 6:24 pm
    Is there another way to go from an FCP 7 timeline to Compressor 4?
    I tried it the following way and it did not work. It failed. When it started encoding in Compressor 4, the Progress bar was not there so I had a feeling something was was wrong.
    In FCP 7
    Click file –>
    Click Send to –>
    Click compressor –>
    Now that the old version of compressor is open.
    Click File –>
    Click Save –> (create s name of you choice)
    (Save in the location you want)
    Now close the old version of compressor
    Next find the .compressor file you just saved.
    Right Click/control Click the .compressor file
    mouse over to open with and you will see both the old and new versions of compressor as options
    select the new version and then you can now use FCP 7 sequences with the new compressor!
    The way I have it set up is I have a folder in my Applications folder that is called “FCP X.” In that folder I have FCP X, Motion 5, and Compressor 4.
    Mac Pro
    10GB RAM
    FCP X
    Compressor 4
    Noah Kadner replied 10 years, 11 months ago 3 Members · 2 Replies
