Activity Forums Apple Final Cut Pro Legacy FCP 7 sync problems
  • FCP 7 sync problems
    Posted by Alex Ryan on November 19, 2010 at 3:58 am
    I am having a syncing problem.
    The audio is lagging behind the vision in FCP at a constant of about 5 frames. the same files do not do this when played back in the finder. When I export from FCP there are no sync problems. It is only during playback that the problem occurs.
    The footage was shot on a cannon 5D at 25fps, transcoded to prores HQ. 16bit 48KHz sound.
    I am working off a firewire 800 drive. The computer has plenty of ram and I have never encountered this problem using the exact same settings, codecs and hardware.
    Any ideas
    Jaap Van hoewijk replied 15 years, 9 months ago 2 Members · 1 Reply
  • Jaap Van hoewijk
    November 19, 2010 at 8:47 am
    do you use a capture/playback card like black magic, kona?
