Activity Forums Apple Final Cut Pro Legacy FCP 7 Stuttering Playback
  • FCP 7 Stuttering Playback
    Posted by Harrison Gruber on May 23, 2014 at 4:40 pm
    I was editing ProRes 422 footage just fine on my macbook when all of a sudden playback began to stutter. (Running Snow Leopard, USB 3.0 connection to Ext. HD with plenty of room to spare on both External and Startup drives) Have tried adjusting Playback quality, running disk utility, restarting computer, and nothing works–. Any possible fixes are appreciated.
    Shane Ross replied 11 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Harrison Gruber
    May 23, 2014 at 5:16 pm
    Hmm..I have some graphics I’ve brought in from MOTION. You’re right, that’s probably what it is. Thank you!!!
  • Shane Ross
    May 23, 2014 at 5:53 pm
    The drive you have might have a USB 3 connection…but does your computer? If you are running Snow Leopard, that means you are running and older machine…older macs didn’t have USB3…they had USB 2. Only computers made starting in 2012/2013 have USB 3.
    And USB 2 isn’t good for editing. Barely works for DV…won’t work at all for HD ProRes.
    Shane
    Little Frog Post
  • Harrison Gruber
    May 26, 2014 at 6:22 pm
    You are correct in that it’s a USB 2.0 however it edits HD ProRes footage just fine.
  • Shane Ross
    May 26, 2014 at 6:36 pm
    Well, apparently not anymore. I’ve never had success with USB 2 and ProRes HD on FCP.
    Shane
    Little Frog Post
  • Roger Poole
    May 26, 2014 at 10:47 pm
    I agree with Shane. The problem with USB is not speed but the way USB sends data in packets rather than a stream. For editing we need Firewire, eSata or thunderbolt external drives. Fiber channel for high end users.
  • Harrison Gruber
    May 27, 2014 at 1:57 am
    I’ve never had a problem editing HD ProRes using the USB 2.0 port on my macbook. The problem I was having was being caused by something else and I fixed it by trashing the Prefs for FCP.
  • Aynsley Baldwin
    April 26, 2015 at 1:34 am
    Hi folks,
    I am encountering the same problem here, but with media on an internal drive on my MacPro tower (separate from the system drive). It’s a 7200 RPM, and I swear I used to be able to edit ProRes with this system before, without stuttering. Not sure what the issue is now! Footage even stutters straight out of the viewer window. I am running FCP 7 on an 8 core MacPro4,1 with Snow Leopard. Any thoughts?
    Aynsley
  • Shane Ross
    April 27, 2015 at 6:16 pm
    HOw full is the drive? The fuller they get, the slower they get. If there isn’t 15% of the drive free of stuff, it’ll be really slow
    Shane
    Little Frog Post
