Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Stops Responding during Playback
  • FCP 7 Stops Responding during Playback
    Posted by Ron Whitestone on June 27, 2012 at 5:28 pm
    I just finished about 17 minute project. I did some color work and then just finished up my work from Sountrack Pro. I brought the XML file back into FCP and after opening up the sequence FCP now stops responding. I get the spinning rainbow wheel and it won’t go away. I try to restart the program and it happens again and again. This is the first project this has ever happened on. Any ideas what could be wrong so that I don’t lose all the work I just did?
    My stuff is saved and opens back up perfectly fine and then the “Application Not Responding.”
    That’s the info from the report I get when I close the program.
    Event: hang
    Duration: 8.00s (sampling started after 2 seconds)
    Steps: 39 (100ms sampling interval)
    I’ve figured out that it only happens when I try to playback my video. When I open the project I can edit, render, save, export, ect… but but once I press space to play back my timeline it stops responding and doesn’t catch up.
    I already trashed my preferences and that didn’t work.
    Thanks in advance for any help!
    Ron Whitestone replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
