Activity Forums Apple Final Cut Pro Legacy FCP 7, Snow Leopard, and XDCAM….is it safe yet?
  • FCP 7, Snow Leopard, and XDCAM….is it safe yet?
    Posted by Tim Allison on February 26, 2010 at 4:39 pm
    We’re looking to upgrade our edit systems. Are most of the “new version” kinks worked out to make it worth while to move up from FCP 6 and OS 10.5 up to FCP 7 and OS 10.6? I know FCP 7 has some features that we need.
    Tim Allison replied 16 years, 6 months ago 4 Members · 5 Replies
  • Colin Mcquillan
    February 26, 2010 at 7:37 pm
    Working great for me.
    The only issue I’m having is with large speed changes using the new timeline dropdown speed keyframes. When changing speed from 300% or more to 100% or less I get a stutter frame on the key frame.
    Colin McQuillan
    Vancouver, B.C.
  • Colin Mcquillan
    February 26, 2010 at 7:41 pm
    I should add that that is a fcp7 issue, not an OS or codec issue as it occures on both my leapord based tower and on my snowleapord mbp.
    Colin McQuillan
    Vancouver, B.C.
  • Zane Barker
    February 27, 2010 at 3:10 am
    A search of the forums will provide plenty of info on your question, as it has been asked many times.
    Hindsight is always 1080p
  • Jaap Van hoewijk
    February 27, 2010 at 1:20 pm
    if you do a clean install of both the os and fcp it’s safe. I work with the same setup and since the last updates of XDCAM Transfer everything works as it should.
  • Tim Allison
    March 1, 2010 at 3:29 pm
    Zane, thank you so much for your helpful response. Do you have XDCAM equipment in your editing system?
