Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Share Failure for bluray file
  • FCP 7 Share Failure for bluray file
    Posted by Evan Smith on December 12, 2013 at 5:49 pm
    I have been trying to share a bluray DMG for a while now and it keeps failing. I have done this dozens of times with this same project file (using the right click, “share” procedure) but all of a sudden, it’s stopped working. The current error says “Share Failure 2X QuickTime Error: 0”
    This message is not always the same. I’ve also seen “3X Service Down”.
    Has anyone encountered this before?
    John Fishback
    replied 12 years, 9 months ago
    2 Members · 1 Reply
  • John Fishback
    December 12, 2013 at 10:41 pm
    I’ve not seen that error, but when odd things happen with FCP I trash prefs, run Disk Warrior and then repair permissions.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
