Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 “share” DVD burn time.. what am I doing wrong??
  • FCP 7 “share” DVD burn time.. what am I doing wrong??
    Posted by Graham Dickinson on May 17, 2010 at 4:27 pm
    Im burning a 30 minute run time DVD in FCP with a TC window burn and using the “share” feature to burn the DVD.. it says its going to take more than 2.5 hours to complete. This seems terribly slow for such a high end editing system. Are there settings I need to change or anything I should be doing differently to speed this up??
    (It’s all HD from a Sony Z1U)
    Graham Dickinson replied 16 years, 4 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    May 17, 2010 at 4:36 pm
    Native HDV… ugly for render/compression times.
    How long is the sequence? If it’s native HDV or any other GOP structured media, render/ compression times take much much longer than say ProRes or other all “i” frame media.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Mark Maness
    May 17, 2010 at 7:06 pm
    [Jerry Hofmann] “If it’s native HDV or any other GOP structured media, render/ compression times take much much longer than say ProRes or other all “i” frame media. “
    Partially, true…
    I have found that this feature is nothing more than a marketing gimmick. It sounds nice and looks nice but it’s extremely slow. On a 30 minute program, pretty much any compression, you’re looking at least 2 1/2 hours just to compress and write. Last time I tried it with a ProRes422 timeline, the estimator said it was going to take 9 hours to compress, and this was after about 20 minutes of compressing.
    Your much better off using Compressor or DVD Studio Pro for this.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Graham Dickinson
    May 17, 2010 at 7:38 pm
    The sequence is all HDV 1080/60. Sounds like I just better get used to the lengthy burn time with that share feature. Thanks to you both, very helpful!
