FCP 7 Render plays edit double time, then goes black
So FCP 7.0.3 is acting real weird. My renders are playing some clips back at a faster speed, and then cutting to black while still in the middle of the clip. I haven’t TOLD FC to change the speed, and the clip isn’t running out of frames from the source footage. My sequence and footage both match, using XDCAM EX 1080p30 (VBR) codec.
I first noticed this yesterday with individual clips which I had modified the playback speed on. But today everything is WORSE. I’ve tried trashing my render files, and also my preferences, but it keeps rendering with these funky black parts which last for long times. And now some parts I render are squishing a bunch of clips together at the fast speed before going to an even longer stretch of black. And to clarify, the timeline isn’t changing at all. So the render is displaying edits happening in the middle of what is CLEARLY a single clip in the timeline. Audio is not effected. Displaying the clip keyframes shows that everything SHOULD be playing at 100%.
I’ve used “AJW’s Pixel Mask” filter on some clips to cover a stuck pixel, and those clips are some of the ones in question, but I tried deleting the filter from all clips in a duplicated sequence, and the render still did the same thing.
I’ve also tried copying clips into a new sequence, and it still renders wrong. Last night I trashed the render files and then exported through compressor, and it seemed to export correctly. But this morning, after rendering, my export had the same black parts as the rendered playback in FC.
Any thoughts or suggestions?
