Activity Forums Apple Final Cut Pro Legacy FCP 7 relinking question
  • FCP 7 relinking question
    Posted by Ben Edwards on June 30, 2012 at 1:19 pm
    I have a project where I have a media managed version but want to link back to the non media managed footage as the 2 second handles are not enough (doing major edits). This has actually worked surprisingly well (although time consuming as I have to locate each clip manually). My question is after manually relinking does FCP remember the new media file names so if I move the non media managed media will relinking be easy.
    For example I have a clip called bob and the media managed media was called bob-1. I can manually link to the non media managed media (called bob). If I then move the bob media and reconnect the media will FCP look for bob or bob-1?
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
    Ben Edwards replied 14 years, 2 months ago 3 Members · 3 Replies
  • Bret Williams
    June 30, 2012 at 6:12 pm
    Bob.
  • Shane Ross
    June 30, 2012 at 7:10 pm
    If you media managed and the new files are not exactly the same length as the originals…if they are selects with handles…those will not relink to the original full-sized clip without third party app help.
    You’ve said you’ve done this before without issue?
    Shane
    Little Frog Post
  • Ben Edwards
    July 2, 2012 at 12:09 pm
    Yes, seems to work fine. It does complain about media start/end but it seems as long as the media in the clip exists in the media file it relinks, even if the media is longer.
    I do have to locate the clips manually but as I said in the MM project if the blip is called bob-1 then I try the fill clip called bob and it works.
    Ben
