Activity Forums Apple Final Cut Pro Legacy FCP 7 reconnect problems!
  • FCP 7 reconnect problems!
    Posted by Alex Ryan on August 14, 2010 at 7:56 am
    I am having problems reconnecting media.
    The media is not offline in the browser, but it is in the timeline.
    I tried reconnecting the media and even though there is a file with the same name on my HD it wont let me select it even when I reconnect manually.
    When i tried revealing the file in the finder it cant locate it, even though it is on the HD.
    I have already done alot of work on this sequence and dont want to have to recreate all the edits again.
    Has anyone encountered this problem before, and did you come up with a solution?
    Alex
    John Fishback
    replied 16 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    August 14, 2010 at 6:48 pm
    Have you trashed prefs and repaired permissions? Also, run Disk Warrior.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
