Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Pref Anomoly
  • FCP 7 Pref Anomoly
    Posted by Peter Tours on October 12, 2011 at 1:32 pm
    Does anyone know why this second and odd set of prefs is appearing along with the normal prefs? 3064_screenshot20111005at4.56.51pm.png.zip
    7.0.3
    10.6.7
    12 Core 12gb RAM
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to infinity and beyond!
    Peter Tours replied 14 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    October 12, 2011 at 2:49 pm
    Because they exists in your User >Library > Preferences > By host.
    rafael
    http://www.nagavideo.com
  • Peter Tours
    October 12, 2011 at 3:13 pm
    I don’t understand. Did you look at the screen grab? Please explain. I understand prefs pretty well. Plse look at the screen grab.
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
  • Andy Neil
    October 12, 2011 at 6:22 pm
    Well, you didn’t stretch the name out so it was entirely visible so I can’t be sure what it is or how it got there. However, you’re clearly only supposed to have one FCP plist so I’d delete the “long name” one.
    Andy
    https://www.timesavertutorials.com
  • Peter Tours
    October 12, 2011 at 6:44 pm
    Not sure what you guys are seeing – when I download the image I see what I uploaded. It’s a find, but reflects what was in finder in the prefs folder. The red labeled item is the whole name of a pref file that should not exist on this planet as far as I know. The entry above the red labeled line is the normal pref file I would expect to see.
    If you don’t see that, let me know and I will send you the image. Thanks!
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
  • Andy Neil
    October 12, 2011 at 7:10 pm
    Usually you see the “…” in a name in the finder when the OS is truncating a longer name. If you drag the name column edge out does the name lengthen?
    Andy
  • Peter Tours
    October 12, 2011 at 7:15 pm
    Sorry I trashed prefs after the grab. That was actually what I set out to do when I discovered the anomaly. peter
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
  • Rafael Amador
    October 13, 2011 at 6:09 am
    Again, that file is user/Library/Preferences/By Host.
    I guess is something for the system, not for the user manipulation.
    What I don’t understand is why that window doesn’t shows the path to the file as in my computer.
    Look at the bottom of the picture:
  • Peter Tours
    October 13, 2011 at 6:33 am
    I thought you were getting too humg up on the fact is was a search, but now I get the impression it’s supposed to be there and maybe not the anomoly I thought it was.
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
