Activity Forums Apple Final Cut Pro Legacy FCP 7 – Playback fine within program – Sutter on Export
  • FCP 7 – Playback fine within program – Sutter on Export
    Posted by Paul Charles on August 3, 2015 at 7:15 pm
    Greetings
    720p 30fps AVCHD – Encoded by FCP at recommended 422LT looks fine when played within the program, but encounters stuttering (mainly on pans) when exported as Same as Source…or any of the Quicktime Conversions (QT 7.7)one can think of. Sequence is only 1:30.
    Looks like a frame rate issue, but appears not to be, as I have been meticulous in trying to troubleshoot this problem.
    I am on an older system (see below). Could this be a hardware issue?
    Any thoughts, or work-around would be greatly appreciated!
    Thank you so much.
    – Paul
    Mac 10.5.8
    2 x 2.66 Duel Core Intel Xenon
    4 GB 667 MHz DDR2 FB-DIMM
    Paul Charles replied 10 years, 9 months ago 2 Members · 7 Replies
  • 7 Replies
  • Joaco Güiraldes
    August 3, 2015 at 7:46 pm
    Did you encode the files to Prores before importing? Or are you using the AVCHD files in a Prores sequence?
    Alternately, could it simply be a playback issue?
    Recently I had trouble with AVCHD but found a pending update in the App store which specifically solved errors with AVCHD in Final Cut. I don’t know if it will be available for 10.5.8 though.
    Also, when exporting using “Current Settings”, try with “Make movie self compressed” and “Recompress all frames” are both checked.
  • Paul Charles
    August 3, 2015 at 8:06 pm
    Thank you for the quick response!
    Yes. The files were encoded to ProRes 422 LT. I also tried 422 HQ, through both FCP itself and PavTube converter.
    I have tried both compressing all frames and self contained movie.
    I have noticed on playback, when monitoring framerate in QT, that it seems to vary and not hold true to the assigned framerate. I don’t know if that’s just the way QT is or some other issue. Again, the movie when opened within FCP, plays fine without stutter.
    Thank you again.
    Paul
  • Paul Charles
    August 3, 2015 at 9:16 pm
    Hi Dave –
    I have tried several in an attempt to fix this problem.
    Footage was shot 720p 30 AVCHD on a Panasonic 130A, footage was converted to ProRes 422 LT 29.97, sequence settings 29.97, Compressor settings ProRes 422 LT.
    I have also tried encoding footage at 59.94, and using a 59.94 sequence/compressor settings.
    Same issue upon export.
    Thank you.
  • Paul Charles
    August 4, 2015 at 2:02 am
    Yes…when re-imported into FCP, the stuttering file…no longer stutters.
  • Paul Charles
    August 4, 2015 at 5:22 pm
    Good Afternoon Dave –
    I gave that a “whirl” as well…with the same results.
    A new and interesting observation however…playback in QuickTime 10.1 seems fine (playback framerate also seems to be locked in at 29.97 with QT 10.1 …whereas in QT 7.7 it fluctuates).
    Any thoughts on this would be greatly appreciated.
    – Paul
  • Paul Charles
    August 5, 2015 at 4:50 pm
    Hi Dave –
    I copied the file onto a Mac Air…running QT 10.1…and the file plays fine. So, I’m not sure I’ve really “solved” anything, except to determine that the file itself is “fine”. I’ve also viewed the file on a smartphone…without issue.
    So knowing it’s a playback issue…do you know of any root causes of this except…to guess my system needs to become a boat anchor?
    – Paul
  • Paul Charles
    August 5, 2015 at 6:01 pm
    Thanks for all the help Dave. I do appreciate it.
    If I find a solution, I will follow up if anyone else is experiencing the same issue.
    – Paul
