Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Out of Memory Message
  • FCP 7 Out of Memory Message
    Posted by Danielle Bernstein on November 5, 2014 at 11:25 pm
    I am in the last week of editing a feature length documentary with a lot of footage. Almost 30 TB worth and the FCP 7 file is around 115mb, which I know is a bit big. My scratch disks are set to one of the drives that shows 4TB available but I am getting an “Out of Memory” message when I try to render or export.
    I am not sure what is out of memory. Could it be the graphics card?
    Any help would be greatly appreciated. We have some big deadlines coming up next week!
    my email is clearfilmsproductions@gmail.com
    Ale Corsini replied 11 years, 2 months ago 6 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    November 5, 2014 at 11:53 pm
    Do you have any stills in your project? Any non-FCP codec media, like h.264 or mp4?
    Shane
    Little Frog Post
  • Mark Suszko
    November 6, 2014 at 4:22 am
    Stupid question: did you actually empty the trash?
  • Jerry Wise
    November 6, 2014 at 3:57 pm
    in sequence settings/video processing/ set it to RGB or 8 bit YUV.
  • Danielle Bernstein
    November 6, 2014 at 5:03 pm
    I do have clips that were converted from mp4’s to 422 in the sequence.
    I will try this. Thank you.
    November 6, 2014 at 5:05 pm
    I did 😉
  • Cal Deal
    November 10, 2014 at 5:30 pm
    Same problem. Activity monitor shows memory pressure climbing. This was happening in conjunction with Image Capture Extension. I deleted the extension, now Final Cut is doing it alone. Beach ball won’t stop. Can’t do anything.
    I’ve already had to delete the entire project and start over!!!
    I’ve used Carbon Copy Cloner to make regular backups of the entire folder, so I hope I can salvage it. But the backup shows a Nov. 4 date, and I worked over the weekend.
    Library’s name seems to have changed to Untitled. Can’t access Events. File seems corrupted.
    What the heck is going on????
  • Ale Corsini
    July 25, 2015 at 1:59 pm
    GENIUS! you solved my problem! Thank you very much!!!!
