Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 & Livetype
FCP 7 & Livetype
Posted by Jim Hoey on January 26, 2012 at 11:50 pmI bought a new imac and loaded FCP 7 upgrade- no livetype! I have my original FCS disks with livetype – can I just load the livetype disks or will i get issues??
Daw Frame replied 13 years, 4 months ago 6 Members · 10 Replies -
Jerry Wise
January 27, 2012 at 4:54 pmhummm….when we got our FCP 7 systems a few years ago the people here complained that there was no livetype. they were used to it in FCP 6. it’s in Motion tho. so…if i can get hold of the FCP 6 disks i can load livetype into FCP 7 ???
Mark Suszko
January 27, 2012 at 6:00 pmI believe you can, if stand-alone Livetype is what you perfer. One of our editors did this.
Jerry Hofmann
January 27, 2012 at 6:08 pmDitto the other posts, and I too like livetype. It’s a dedicated titler, even though Motion will do the same, it’s just a more “dedicated” tool for the creation of titles.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Bret Williams
January 30, 2012 at 5:48 pmAnd Motion doesn’t do EVERYTHING livetype did. Extruded text for one.
Daw Frame
May 23, 2013 at 4:38 pmHi, I am using FCP 7 with LiveType 2… seems to be good but wish I had more templates and effects… seems they have all dropped out of sight on the internet… although LiveType clearly has its uses as a fast and simple titler.
I filmed my video on a Canon T3i and transcoded my files to ProRes 422 … and they appear in my FCP 7 browser and all is hunky dory. Furthermore, my frame size is 1920 x 1080 and rate is 25 fps. Audio rate 48 KHz. What confuses me is I don’t know what my settings in LiveType should be. That is, what should my Project Preferences in LiveType be so that they dovetail with my project in FCP 7?Would appreciate understanding how this works better.
many thanks, D
Jerry Hofmann
May 23, 2013 at 9:58 pmMake the project settings in LiveType the same as your sequence’s settings.
Jerry
Current DVD:
Daw Frame
May 24, 2013 at 11:09 amThanx, yes, I can understand your answer, and I appreciate it, however, I still don’t have all of the info to do this. My sequence settings are for ProRes 422. According to the summary on this preset in FCP 7, I have certain information concerning the sequence settings and based on this I can fill out some of the settings fields in LiveType.
When I go over to LiveType, I presume I must do a custom Project Properties (I can save it thereafter). To set Custom settings, the first box is Width, 1920 px (ok) this is followed by ? inches at ? dpi. Then there is Height, 1080 px again followed by ? inches at ? dpi. This is followed by Frame Rate 25.00 fps, Field Dominance None, then Pixel aspect ?
So basically, where there are ” ? “, I do not have the data to enter into the boxes, i.e., For Width and Height, what values should be entered for ____ inches at _____dpi. Nor do I know what I should set Pixel aspect to.
The reason I can’t set them is because I don’t understand the significance of these values. Can anybody explain the significance of these values and what they should be for ProRes 422?
Many thanks for your help with this. All the best, D.
