What would you have there instead? If it’s smaller…then something needs to occupy that space. What do you want to put in that space so it’s not “wasted?”
Your timeline window is separate from the rest…grab the bottom right corner and drag it smaller until that area is gone. Then move it down and BAMMO! You have space between your timeline and the monitors. You can fill that with…whatever you are planning to fill that with.
Although I have no clue what that might possibly be. Oh, the Timecode Window…
Shane
Little Frog Post
