Activity Forums Adobe Premiere Pro FCP 7 key commands in Premiere
  • FCP 7 key commands in Premiere
    Posted by Arturo Glass on May 1, 2014 at 3:54 pm
    I’m new to Premiere and chose the FCP 7 keyboard configuration within it, but some things don’t work the same. For example, in Final Cut Pro, when I hit SHIFT+X it deletes the selected clip and shifts all the footage back to fill the gap. In Premiere, how do I do this?
    Second question – what’s the Premiere equivalent of OPTION+down arrow? That is, how do I shift elements up or down along the available tracks?
    Finally, If I cut clips that are on audio and video tracks 2, when I go to paste them they revert back to track 1. How can I make them retain the same tracks when pasting?
    Kevin Monahan replied 12 years, 4 months ago 3 Members · 5 Replies
  • Peter Garaway
    May 1, 2014 at 4:39 pm
    [Arturo Glass] ” I hit SHIFT+X it deletes the selected clip and shifts all the footage back to fill the gap. In Premiere, how do I do this?”
    This one is called ‘Ripple Delete’ Option+Delete
    [Arturo Glass] “what’s the Premiere equivalent of OPTION+down arrow? That is, how do I shift elements up or down along the available tracks?”
    This is called ‘Nudge Clip selection Up/Down. This one is not assigned by default in the FCP KB commands, but its Option+UP/Option+Down in Premiere Pro KB commands. That keyboard command is available in FCP KB commands.
    [Arturo Glass] “If I cut clips that are on audio and video tracks 2, when I go to paste them they revert back to track 1. How can I make them retain the same tracks when pasting?”
    https://helpx.adobe.com/premiere-pro/using/source-patching-track-targetting.html
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Arturo Glass
    May 1, 2014 at 4:56 pm
    Thanks Peter. I’m really trying to like Premiere but getting over the hurdles of being an FCP user for years.
    One more question you may be able to help with. Are there ways of speeding up the launch of the program on OSX? It seems to take a lot of time to load
  • Peter Garaway
    May 1, 2014 at 5:07 pm
    The launch time will vary per system but theres ways to optimizer this process. Do a search and lots of suggestions will come up. But here’s the general rule.
    OS and Programs on 1 drive and everything else on another or split between multiple. Something like:
    1: OS/Programs
    2: Projects
    3: Scratch
    4: Media
    5: Exports
    Hope this is helpful.
    Peter Garaway
    Adobe
    Premiere Pro
  • Arturo Glass
    May 1, 2014 at 9:26 pm
    Thanks for that. Very helpful.
    One last question – in FCP when I have two clips and want them to lay flush against each other, one way I do that is select the second clip and hit the MINUS key and a numerical value. If it’s more than the space between clips, it leaves them flush against each other. I tried this with Premiere and it overlapped them. Is there a way to make one clip stop the other from moving further?
  • Kevin Monahan
    May 1, 2014 at 11:17 pm
    Hi Arturo,
    Here is just one of the ways Premiere Pro and FCP differ. However, I never adjoined clips the way you described in Premiere Pro or FCP.
    Personally, I think it is much easier to do one of the following:
  • With snapping on, drag the clip until it snaps to the edit point of the other clip.
  • Select the space between the clips and press Delete.
  • Mark Clip (X), then Ripple Delete (Option + Delete)
  • Let us know if these work better for you.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
