Activity Forums Apple Final Cut Pro Legacy FCP 7 – Issues with Image increasing in lightness.
  • FCP 7 – Issues with Image increasing in lightness.
    Posted by Patrick Jones on December 14, 2013 at 12:18 am
    Working with Sony AVCHD converted to quicktime using using Media Converter. Shot in 1080P/24P and 1 clip in 1080P/60P (for a freeze frame in the middle of the clip). Sequence Settings Screen Shot and Attached here.
    I add a cross dissolve and the gets in brighter until the cross dissolve is done, then it goes back to normal color. Time ramping a clip changes the brightness of the clip as well. Selecting the frame #, take a freeze frame and putting in-between two clips shows the freeze frame to also be brighter.
    Any help would be appreciated.
    thanks so much
    FCS 3 – MBP 2.93ghz 4gb RAM, 300gb 7200 Internal HDD, iStarUSA Dual Dock with (10) 1TB 3.5 Seagate Barracuda drives, and a couple 250’s Maxtors, and Seagates.
    Patrick Jones replied 12 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Patrick Jones
    December 14, 2013 at 1:09 am
    Hey there – I did In my post and attached image.
  • Patrick Jones
    December 14, 2013 at 1:20 am
    Yes, Im aware, that’s why in my OP I said it was covered using MC to QT. Let me see if I can Attach the image again here.
  • Shane Ross
    December 14, 2013 at 1:28 am
    [Patrick Jones] ” Hey there – I did In my post and attached image.”
    Nope…all you said in the original post was: “Working with Sony AVCHD converted to quicktime using using Media Converter.” You didn’t say what you converted to…?
    And there is no screen shot attached.
    Shane
    Little Frog Post
  • Patrick Jones
    December 14, 2013 at 2:54 am
    Thanks – The Screen shot was uploaded, just didn’t paste the code 🙂
    Sony AVCHD converted TO quicktime using using Media Converter.
  • Nick Meyers
    December 14, 2013 at 9:53 pm
    but what codec is the quicktime?
    your screengrab shows your SEQUENCE settings only
    if you’ve just re-wrpaped the avchd that could be the problem.
    it would be best to actually convert it to Prores
    nick
  • Mark Suszko
    December 16, 2013 at 4:39 pm
    What dissolve are you using? An “additive” dissolve?
  • Patrick Jones
    December 21, 2013 at 6:03 am
    Just basic. Cross Dissolve. nothing fancy. When I remove the cross dissolve, the image still stays the brightness… just a weird issue…
    Update: I created a new sequence. AppleProRess422HQ and copy and pasted… rendered… took a lot longer, 1.5 hours for 5 mins… LOL but no issues.
