Activity Forums Apple Final Cut Pro Legacy FCP 7 – Improved render management?
  • FCP 7 – Improved render management?
    Posted by Chi-ho Lee on September 10, 2009 at 4:21 pm
    I’m doing some light editing on 7 and have been playing with some rendered clips….
    I rendered a speed change on V2 at 100% opacity. I have a clip underneath on V1. I can turn on/off visibility on V1 and clip on V2 stayed rendered. Is this new? Can’t remember how it was on 6.
    I can trim clip underneath the rendered clip on V1 and the clip on V2 stayed rendered. Is this new?
    I can slide the rendered clip on V2 with a clip underneath on V1 – and the rendered clip stayed rendered. Is this new?
    CHL
    Chi-Ho Lee
    Film & Television Editor
    Apple Certified Final Cut Pro Trainer
    http://www.chiholee.com
    Alan Lacey replied 17 years ago 5 Members · 15 Replies
  • 15 Replies
  • Jeremy Garchow
    September 10, 2009 at 4:50 pm
    [Chi-Ho Lee] “Is this new? “
    From here:
    https://www.apple.com/finalcutstudio/whats-new.html
    Render management enhancements reduce the need to re-render as you trim clips, move media, and perform a wide range of other functions. This means you can work more efficiently as you experiment with creative options.
    Jeremy
  • Shane Ross
    September 10, 2009 at 5:14 pm
    [Chi-Ho Lee] “I can turn on/off visibility on V1 and clip on V2 stayed rendered. Is this new?”
    Sorry…I cannot replicate that behavior. Jeremy, can you?
    I have clips on V1, and text on V5. I render the text….then turn off visibility on V5…get the usual warning….then turn it back on…and I have to re-render.
    Shane
  • Jeremy Garchow
    September 10, 2009 at 5:24 pm
    I can replicate exactly what Chi-Ho Lee says, yes, but the test doesn’t involve alpha channels/transparency.
    Jeremy
  • Chi-ho Lee
    September 10, 2009 at 5:37 pm
    Yes, what Jeremy said. Cuz your text has an alpha, that won’t work. But try a regular clip with a filter and turn off the lower tracks, not the higher track that contains the rendered clip.
    So, Jeremy – is this a new behavior? Was this possible back in 6?
    CHL
    Chi-Ho Lee
  • Shane Ross
    September 10, 2009 at 5:38 pm
    OK…what are you guys doing EXACTLY? Because I cannot replicate this. I took a clip, put it on V2, with a clip on V1. I added a Gaussian Blur to the clip on V2, rendered. Then I turned off the V2 track visibility. Got the same error. Turned it back on….the clip was unrendered. No opacity, no alpha channel, no text.
    Shane
  • Jeremy Garchow
    September 10, 2009 at 5:39 pm
    [Chi-Ho Lee] “So, Jeremy – is this a new behavior?”
    Yes, and a welcome one.
    [Chi-Ho Lee] “Was this possible back in 6? “
    No. The link I have you earlier was to the new features of FCP7. Render management being one of them.
    Jeremy
  • Shane Ross
    September 10, 2009 at 5:42 pm
    Wait…turning off the LOWER tracks? The ones BELOW the clip you have rendered? Why on earth would that unrender your footage on the higher tracks? I see that it does…but WHY?
    And sorry, but I have a clip on V3 now, with BLUR, one on V2, with BLUR. I turn off V2 and…unrendered. I turn back on V2…still unrendered. Is there a system or user setting somewhere for this behavior?
    Shane
  • Jeremy Garchow
    September 10, 2009 at 5:48 pm
    Take the blur off of v2 and just keep it on v3. Render. you can now trim underneath v3 and physically move v3 without it becoming unrendered.
    Jeremy
  • Shane Ross
    September 10, 2009 at 5:57 pm
    [Jeremy Garchow] “Take the blur off of v2 and just keep it on v3. Render. you can now trim underneath v3 and physically move v3 without it becoming unrendered. “
    Sorry. Again, I cannot replicate this behavior. I add blur to clip on V3…nothing to clip on V1. I render. I turn off visibility on V1…the clip becomes unrendered. I UNDO…it’s fine. I move the rendered clip anywhere…it becomes unrendered.
    UNLIMITED RT in my RT settings…what is your secret?
    Shane
  • Jeremy Garchow
    September 10, 2009 at 6:09 pm
    [Shane Ross] “what is your secret? “
    FCP7?
    Jeremy
