Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 – Gaussian Blur Background
Posted by Jake Van vuuren on October 26, 2019 at 8:32 pmHello Folks,
Anybody has a good tutorial or video on How To Blur the Background of a talking head? Do you even get good results doing this effect in FCP 7? I’m not a Motion expert.
Jake
jakevv
Mark Suszko replied 6 years, 10 months ago 4 Members · 3 Replies -
David Roth weiss
October 26, 2019 at 9:32 pmIf your subject moves at all while chatting to camera you’re going to have a tough time, as you’ll probably be rotoscoping, or fixing a zillion keyframes on a frame by frame basis. Adobe has an automated plugin for rotoscoping, but it doesn’t work perfectly, meaning you’d still have to fix many of its mistakes on a frame by frame basis. Shooting with a soft background is NOT one of those things best fixed in post.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los AngelesDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro Legacy forum.
Nick Meyers
October 29, 2019 at 1:08 ama lot depends on how detailed / accurate you want the separation between fg/bg to be.
if you don’t want too much detail / accuracy, then FCP7 can do the job.the basics are pretty obvious
duplicate your clip/s into two layers, say V1, V2, (option short drag a clip upwards to dupe it)
apply a blur or defaces to V1, apply a garbage matte to V2.
it could be as simple as a diopter effect, where there’s a simple soft line delineating the bg,
or a more complex shape around your fg subject.
keep the shape loose so you don’t have to do a zillion key-frames.see if you can still find the Paul Crisp garbage metres on line somewhere.
with those you can keyframe the position of your shape as a whole.
makes life a lot easier.for anything more complex however, you’d need to go outside of FCP7.
Resolve is free, and has these sorts of tools.cheers,
nick -
Mark Suszko
November 8, 2019 at 10:42 pmYes, when I did this the Paul Crisp multi-point mask tools were a Godsend, especially since they could be feathered. If you do a DEEEP search of the COW archives for Paul Crisp it may turn up still-not-dead link to those masks, which came in 4,6, and 12-point versions, maybe more.
