Activity › Forums › Apple Final Cut Pro › FCP 7 Frame blending in FCPX?
  • FCP 7 Frame blending in FCPX?
    Posted by Mark Linthicum on July 25, 2015 at 7:25 pm
    Is there a way to get the old FCP 7 Frame blending in FCPX? It has nothing to do with slowing clips down, is just blended fames before and after into the current frame.
    Thanks, Mark
    Thanks, Mark
    Jeff Kirkland replied 11 years, 2 months ago 3 Members · 3 Replies
  • Noah Kadner
    July 26, 2015 at 9:48 pm
    Can you elaborate? Frame blending is a option used as part of retiming vs none or optical flow. All of which are options in the Retiming Editor. If you’re looking for a kind of transition give more details.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Mark Linthicum
    July 27, 2015 at 5:59 pm
    If you ever used FCP7 you would see that Frame blending option works differently that in the current version.
    I went to After Effects for the effect. Wide Time in AE is the same as the old Frame blessing in FCP, i was just hoping it was built into the new FCP.
    Thanks, Mark
    Thanks, Mark
  • Jeff Kirkland
    July 27, 2015 at 9:02 pm
    I’m not sitting in front of a computer I can check on but I’m fairly certain Motion has a wide time effect. If it does what you need, you could publish that as an effect back to FCPX.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
