Activity Forums Apple Final Cut Pro Legacy FCP 7 exporting audio only
  • FCP 7 exporting audio only
    Posted by Terry Wookey on July 25, 2012 at 3:22 pm
    Hi just purchased new iMac running OSX 10.7.4 Now FCP 7 export quicktime is only exporting audio have also tried quicktime conversion but audio only .If I send file out by share I then have video and audio Ok. I have loaded quicktime pro and flip
    Help what have I done wrong
    Hallam Drury replied 13 years, 2 months ago 3 Members · 5 Replies
  • Jessica Mantheiy
    July 25, 2012 at 4:20 pm
    Make sure that if you send it through Compressor that you have the Video “Enabled” under the Encoder tab in the Inspector window. If you are exporting it directly from FCP7, make sure you check your Quicktime settings that Video is checked to output.
    Jessica Muth
    Production Operations Manager
    Video Labs
    Rockville, MD
    301-217-0000
    jmuth@videolabs.net
  • Terry Wookey
    July 25, 2012 at 4:57 pm
    Hi Jessica
    Yes have checked video enabled on both have tried QT conversion as well but the only way to get it working is by share
    Terry
  • Terry Wookey
    July 25, 2012 at 5:00 pm
    Hi Jessica
  • Terry Wookey
    July 26, 2012 at 5:27 pm
    Hi Jessica
    Yes have checked video enabled on both have tried QT conversion as well but the only way to get it working is by share.
    I have just exported mov file with quicktime conversion it worked but still no luck from export QT movie
  • Hallam Drury
    June 30, 2013 at 4:42 am
    Hi mate,
    I had the same problem. You may have found the solution but I thought I’d post for others, like me who were looking up this error.
    When you hit export, make sure you have the MAKE SELF-CONTAINED MOVIE box is ticked. I have been doing heaps of exports then suddenly it stopped working and I was getting all audio. Turned out I that box had become deselected. So make sure that is checked and it should work fine again. 🙂
