Activity Forums Apple Final Cut Pro Legacy FCP 7 editing sequence settings: XDCAM EX or apple pro res?
  • FCP 7 editing sequence settings: XDCAM EX or apple pro res?
    Posted by Steve Coulson on March 26, 2014 at 3:55 pm
    Hi all: When I first starting cutting xdcam ex 50i footage, I found advice to use one of the apple pro res settings for my sequence. I did that initially, but now I am using the XDCAM EX 50i settings to edit. I think that’s because apple is now supporting the xdcam ex codec. But perhaps FCP always has.
    Anyway, I do incorporate a wide variety of video formats in my xdcam ex timelines and occasionally have issues such as the video output freezing or the audio playing but no video display.
    Would I see a visual improvement with apple pro res or would one of those pro res settings make my system more stable or anything?
    Or should I continue using XDCAM ex?
    Thanks for you time
    Steve
    Sascha Engel replied 12 years, 6 months ago 3 Members · 3 Replies
  • Sascha Engel
    March 26, 2014 at 4:15 pm
    I’d definitely go for the ProRes settings, specially if you mix different codecs and sizes.
    Way more stable.
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
  • Bret Williams
    March 26, 2014 at 4:54 pm
    You can set the sequence to XDCam EX, but set the render to ProRes if I remember correctly. That way native footage doesn’t require rendering, but anything added that isn’t XDCam is rendered as ProRes. Best of both worlds.
  • Sascha Engel
    March 26, 2014 at 4:58 pm
    Yup, that pretty much sums it up.
    Sascha Engel
