Activity Forums Apple Final Cut Pro Legacy FCP 7 Dropped Frames after trashing Prefernces
  • FCP 7 Dropped Frames after trashing Prefernces
    Posted by Jim Cooke on August 2, 2012 at 6:24 pm
    I’ve read a ton of other answers for this same question. I was having issues after rendering footage so I trashed Preferences. When I restarted FCP i get dropped frames during playback. I am working with AppleProRes LT sequence settings match the clip. The footage is on an external Glyph raid. I reset capture scratch to that drive. When I open FCP now i get “External A/V Unable to locate the following External devices, Apple Firewire NTSC 720×480” i click check again and nothing. Please any help is greatly appreciated. I am not a super pro.
    That warning was not happening prier to trashing preferences
    The dropped frames issues was not happening prier to trashing preferences
    Jim Cooke replied 14 years ago 3 Members · 4 Replies
  • Jessica Mantheiy
    August 2, 2012 at 9:15 pm
    Check your user preferences. Make sure you don’t have the “Report Dropped Frames” option checked.
    There is also an option within Audio/Video Settings in the very last tab that allows you to report the External Video error.
    Jessica Muth
    jmuth01@gmail.com
  • Rafael Amador
    August 3, 2012 at 12:24 am
    [Jim Cooke] “I was having issues after rendering footage so I trashed Preferences. When I restarted FCP i get dropped frames during playback. I am working with AppleProRes LT sequence settings match the clip. The footage is on an external Glyph raid.”
    And where are the render files?
    [Jim Cooke] ” When I open FCP now i get “External A/V Unable to locate the following External devices, Apple Firewire NTSC 720×480″ i click check again and nothing.”
    If you don´t have any FW external device (Camera or VCR), uncheck “Warn next time” when you get the message.
    rafael
    http://www.nagavideo.com
  • Jim Cooke
    August 3, 2012 at 2:33 pm
    I did have it checked, thanks!
  • Jim Cooke
    August 3, 2012 at 2:36 pm
    Render files are on the same external drive. Which I thought would be powerful enough. I unchecked the Report dropped frames which seems to have solved the constant warning.
