Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Died And I’m Having Re-Install Issues
  • FCP 7 Died And I’m Having Re-Install Issues
    Posted by Alan Nordoc on December 8, 2014 at 9:12 pm
    My FCP 7 started crashing all projects last night so after trying everything I decided to re-install. I upgraded to Yosemite so the installer would work (it didn’t on previous recent versions of the OS) and everything worked great up to the installation of Pro Applications Update 2010-2012. This seems to install fine but it doesn’t actually update FCP to 7.0.3. I just leaves it as FCP 6. Any suggestions about how to get the update to work? My projects are all 7.0.3.
    Thanks.
    Shane Ross replied 11 years, 9 months ago 3 Members · 2 Replies
  • Mark Suszko
    December 8, 2014 at 10:07 pm
    My understanding is that the installer was written to only work in OS versions below Yosemite.
  • Shane Ross
    December 8, 2014 at 10:18 pm
    [Alan Nordoc] “the installation of Pro Applications Update 2010-2012.”
    That updates a fresh FCP 7 install. You said…
    [Alan Nordoc] “This seems to install fine but it doesn’t actually update FCP to 7.0.3. I just leaves it as FCP 6. “
    Did you really install FCP 6? Or is this a typo? The ProApps update you mention only updates FCP 7 to 7.0.3. It won’t touch FCP 6.
    It also won’t update FCP 7 if you already have FCX installed, and in the applications folder.
    Shane
    Little Frog Post
