Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Constant crashing!
Posted by Jesse Kane on May 13, 2013 at 12:05 amHello all, Im not that computer savvy,
I am using FCP7 on 10.7.4, I have used this for quite some time and suddenly my project is crashing pretty much every time I enter trim mode. I have reeinstalled the software and still have the same issues. Any thoughts?
Shane Ross replied 9 years, 7 months ago 7 Members · 17 Replies -
Steve Eisen
May 13, 2013 at 12:26 amPlease do not give us your crash report. If you really want to know what is causing go to https://www.digitalrebellion.com.
They have an app that will trash your preferences. For further troubleshooting you can purchase pro Maintenance Tools.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group -
Jesse Kane
May 13, 2013 at 1:06 amSorry about that, I removed it.
I have tried digital rebellion, I still crash pretty much every time I click between two clips to edit.
William Carr
May 13, 2013 at 3:46 amCould be corrupted clips, and/or you are editing with GOP codec.
Jesse Kane
May 13, 2013 at 4:40 amI’m not sure what a GOP codec is, I am running apple ProRes 422 clips.
I have run a program to detect corrupt media and everthing seems fine.
William Carr
May 13, 2013 at 5:37 amPro Res is good, made for FCP.
If only those two clips are causing the problem, can you re-ingest or re-transcode them from the original format? (Assuming they were originally an mpeg camera record format or from tape.) Even though they seem fine to the program you ran there may be something it’s not seeing that FCP is.
Jesse Kane
May 13, 2013 at 5:47 amIt’s not just the 2 clips, it’s all of them. I am being told that FCP doesn’t like OS 10.7… and I didn’t have problems while running the older OS, so am thinking of going back.
The footage was R3D, transcoded to 422.
William Carr
May 13, 2013 at 5:53 amI’m running FCP 7 on 10.7.5 and have been for a while on a 2010-era MPRO w/ FW800 drives. Never any problems with ProRes, so there may be some other anomaly involved, something else that’s changed if you have used transcoded R3D clips before with no problems. Some other tax on the system.
Jesse Kane
May 13, 2013 at 6:02 amThank you.
As I mentioned, I’m not computer savvy, is there a way to tell what the problem may be, or a place to take the computer to diagnose?
Jon Chappell
May 13, 2013 at 6:03 amAre you running FCP 7.0.3? It’s the only version that is stable for me on Lion.
My software:
Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
More tools…
