Activity Forums Apple Final Cut Pro Legacy FCP 7 Codec error message
  • FCP 7 Codec error message
    Posted by Jacob Zalman on October 7, 2009 at 7:46 pm
    Hi all, I’m having a bit of trouble with FCP7. My videos play fine(I converted all of them to ProRes before importing to FCP) and the composition settings match the videos, but I am unable to apply video transitions. When I attempt to add a transition, I get the error message “codec not found. you may be using a compression type without the corresponding hardware card”. I read some other threads here about this issue and I don’t have any images, let alone images in CMYK in my timeline. This issue only arises after I add a video transition and try to render or export the timeline. Anyone have any ideas?
    Brian Berdan replied 16 years, 8 months ago 3 Members · 3 Replies
  • Tom Wolsky
    October 7, 2009 at 8:26 pm
    What OS is this?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Jacob Zalman
    October 7, 2009 at 9:17 pm
    I’m using 10.5.7
  • Brian Berdan
    December 18, 2009 at 6:24 pm
    Interesting… I just got the same ‘Codec not found error’. I had just done a tv screen replacement in Motion, using a SnapzPro-created temp quicktime. That rendered and played fine back in FCP. I went to do the next one with one additional SnapzPro element, created the exact same way, and those comps won’t render and give the warning.
    FCP 7.0.1
    OS 10.5.8
    ProRes LT 720
    The SnapzPro quicktimes are LT, but just a smaller frame size.
    Brian Berdan
    migrant filmworker
